Who's got a 383 and deals with emissions??
Discussion in 'The Garage' started by CaveBlazin, Aug 29, 2005.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Just like the title states I need to know what you do to pass the sniffer emissions? I have headers and true duals and have not taken the test yet but I dont know if it will pass or not anyone have problems?? Any advice/help would be great. Oh yeah and its nice to be back on the boards in here...
  2. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    ANYONE Deal with emissions that have headers??
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    It depends on the emissions you have now and how many miles your motor has. I run true duals with some good converters.
  4. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Here in eastern Wa. state we don't deal with emmissions,but on the wet side I used to lean out the carb to pass,if it's any help...
  5. dyeager535
    26,982
    191
    If it's just sniffer testing, no reason it won't pass if it's tuned right. Unless you are in CA, pretty unlikely others have gone through exactly what you are attempting to do. Since the rules vary state to state, it's hard to guess at what you will have to attempt. I mean here we have the emissions test done on a roller dyno, and diesels are smogged, I bet those alone are different than your test...
    Visual inspection is another story...true duals in your case is a federal law violation, so unless they do a visual and don't care about that, you'd fail. You say sniffer, so I assume no underhood/undercarriage inspection. We don't have an underhood/undercarriage inspection here.
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    sniffer goes in the tailpipe and reads out what the motor's exhaust is like
  7. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    All they do here is inspect to see if you have a Cat and then run a tester up your exhaust to test the emissions. If your vehicle is a newer model they just hook it up to a puter. I dont have anything you can hook up to on my rig, thank goodness.
  8. dyeager535
    26,982
    191
    So you have dual cats? Do you know if they will fail you for that, or are they just looking to make sure there is one or more present? (also federally illegal to change quantity of catalytic converter, + OR -)
  9. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    Basically you can't screw with your exhaust system under federal law. But in some states it's a sniffer and only check for atleast a cat. So you might be lucky. I would like to know how it goes for you as I am moving to the nashvillie area next year and have dual exhaust and headers on the blazer.
  10. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    My rig should be ready in about 3 weeks and I'll let you know how the sniffer goes.
