Who's got a bigger brake? D60 vs IFS 2500
Discussion in 'The Garage' started by Pookster, May 27, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Who\'s got a bigger brake? D60 vs IFS 2500
    Trying to check for rim clearances.
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Re: Who\'s got a bigger brake? D60 vs IFS 2500
    D60 are way bigger than 2500 IFS.
  3. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    My 99 K2500 front rotors measure in at 12.5" if that helps. This was measured with the rim on so I could be off a 1/4".
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I'll compare my '03 2500HD to the Dana 60 tonight.
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    If this is the case, shouldnt I easily be able to slip a pair of 15" wheels over it? THere are so many more deals to be had on 15" tires than on 16" tires.
  6. johnc
    johnc Registered Member
    May 6, 2004
    68
    O.C., CA.
    don't forget about the calipers !!! /forums/images/graemlins/deal.gif
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    THought about that too. but if a d60 is "way bigger" and a measurement of the k2500's as being "12.5", Even if the caliper outer diamter added two inches, it would still be smaller than 15".
    However, of course, I failed to acutally think about how much the inner diameter of a 15" wheel is /forums/images/graemlins/doah.gif.
    I gotta go measure that tomorrow.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A Dana 60 caliper has something like a 3 1/4" piston, so if you're talking in terms of caliper size, there is little question.
  9. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    If you want I will check the clearance between the rim and the calipar on my K2500?
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    If ya could please. /forums/images/graemlins/smile.gif
  11. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Keep in mind that saying "IFS 2500" is pretty generalized as I'm sure there are several variations in front brakes offered over the years. My '03 2500HD has maybe 1/8" clearance between the front calipers and the stock 16" rims, so there is no way a 15" rim would fit without a lot of grinding. On the other hand an late-80's 2500 with 6-lug rims could probably fit a 15.....
  12. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Good point. Forgot that there were always variances.
    I am referring to the 4wd C/K 2500, model year 1992.
    im sure they increased brake sizes later on.
