Who's got their SBC out of the truck?
Discussion in 'The Garage' started by ZZ4x4, Aug 16, 2005.
  1. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    If someone has a SBC currently out of their truck (73-87), could you simply measure the distance between the motor mount through-bolt holes on your engine cradle? :rolleyes:
    I'm swapping in a SBC where the 6.2 was. I'm not sure on the engine mounts. Some say the SBC can use the same motor mounts that were on the 6.2 and others have said only a BBC will work with the 6.2 mounts. :confused: Anybody know for sure?
    Thx,
    Jeff
  2. JHG
    JHG 1/2 ton status
    Jul 28, 2002
    129
    Iceland
    I am doing the same swap. I had 350 sbc and swapped in 6.2. I used the same engine mounts :)
    Good luck
  3. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    ive got 17" from bolt to bolt with 89 K20 mounts on a 350
    but i THINK 6.2's use the same mounts
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I swapped out a 6.2 for a 350 over christmas. I used the same mounts.
  5. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Thanks all. :bow: Looks like it will be an easy install!
    Best regards,
    Jeff
  6. gambit420s
    May 17, 2005
    294
    :shame: i'd have waited on that statement...
