who's got them?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5_beater, Nov 18, 2002.
  1. k5_beater
    k5_beater Registered Member
    Jun 11, 2002
    35
    New Jersey (Armpit)
    who\'s got them?
    Custom roof racks. i am thinking of building one up and could use some ideas and pics if you got any. thanks. /forums/images/graemlins/eek.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: who\'s got them?
    I've been thinking about doing the same thing, but I'd like to see more pics of how they are mounted as to deal with not having them leak.
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    the stock rack on my sub was drilled right into the roof and had rubber gaskets for the leakin prob. it never leaked. /forums/images/graemlins/thumb.gif
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If you happen to see a burb with a roof rack and no headliner in it, see if you can take a few pics of it would ya?
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Head to the tractor supply store (maybe the hardware store). I mounted up a ladder rack on my work van and was concerned about leaks too (since I was dealing with a new van and electronics). The tractor supply store had these rubber gaskets that had brass nuts mounted in them. So you drill a 1/2 hole drop in the gasket and when you tighten them down the rubber under the cab swells up and seals the hole and make the mount solid when its tightened down. I had alot of weight on the roof rack so I made the mounts set on body lines and in the braced areas. Worked pretty well, no leaks and no silicon. /forums/images/graemlins/thumb.gif
    I used one braket in the front and one in the rear and tied then together with 4" round tubes on the sides with bolts. I still have the roof rack in the garage, its for a 96 astro van if anyone is interested /forums/images/graemlins/smirk.gif
    The metal is zink coated and anywhere I ground or welded, I painted it hot to seal it up (I dont have the rubber gaskets anymore though, I had to seal theholes up when I sold it).
    J
  6. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    Yakima sells tracks that you can bolt right into the top. I have them on my K5 and will be putting them on my dad's Suburban. I haven't had any leaking problems with them ( they come with silicon sealant). If you have a headliner, it will still work! the fastening system is designed to work with headliners. /forums/images/graemlins/grin.gif
  7. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I'll be making a rack/basket for my k5 in the spring.
    But my question is...FLEX...with 4 mounting points on the shell, will it limit flex and crack the shell when off road?
  8. Grim-Reaper
    7,385
    Atlanta
    I think I have seen you around. I saw a K5 with a rack in the last few day's. Were you around hwy5 or Sandyplains recently?
  9. Grim-Reaper
    7,385
    Atlanta
    You might try Search and "Roof Rack", "Roof Racks", "Conferr", Yamika ect. THis comes up regularly. I know there has been a post in the last 25 day's on it.
