Who's ground a stock front driveshaft for angle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84_Chevy_K10, Jul 27, 2002.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Who\'s ground a stock front driveshaft for angle?
    I ground the snot out of the stops on my driveshaft and it fit despite the 6" lift I have.
    Has anyone else done this? Had any problems with it?
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    Re: Who\'s ground a stock front driveshaft for angle?
    I did it after ORD guys suggested it . no probs so far and my driveshaft is past being on its last legs ! /forums/images/icons/smile.gif
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Scott (4X4HIGH) did mine. Have had no problems. /forums/images/icons/laugh.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Cool. The only thing that bothers me about mine is that a 4 speed shaft is really short and I have 6" springs up front, but it seems like it'll work fine until I can get a new shaft.
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    UUUMMMMMMMM! Pics........someone. I will prob need to do this myself when I put my front shaft back in.
  6. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Mine was the same way pre-doubler. It will work with them ground just be concious not to give too much throttle when your right front is drooped down and it will live for a long time
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't have a camera right now. Just grind off all the stops. That means all of them. You'll easily double what the shaft can do for angle.
  8. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Kool Ill have to take a look at my shaft to see exactly whats being talked about.
  9. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    ILL try and get some pics for ya !
  10. kdjohnson
    kdjohnson Newbie
    Jul 31, 2002
    I just did that to mine, the manufacture suggested to remove about 1/8" of an inch. Seems to be fine /forums/images/icons/smile.gif
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    I wouldn't grind the stops all of the way off unless it was a trail only vehicle and real flexy. The stops are there not to limit CV angle (that's up to the suspension), but to keep the driveshaft from hitting the ground. You don't want to use the front driveshaft like a pole vault for the truck if you blow a front U-joint. When you do lift/tires, it takes more angle to do that. In general, you grind the stops until the shaft can almost hit the ground when the U-joint is out of the pinion yoke.
  12. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Very good point Blue. A drive shaft loop would stop that though.
