Who's loud? :)
Discussion in 'Audio' started by Spkrman, Feb 13, 2005.
  1. Spkrman
    Spkrman Registered Member
    Jan 23, 2005
    39
    Matteson, IL
    Any chance any of you guys here compete... or just have a stupid loud daily driver?
    I compete in MECA: www.mecacaraudio.com . This will be my second year... last year took 6th place in both m2 and db2.
    It got up to a 154.0 in m2, and a 126.6 was its peak in driveby (6 feet from the car, 4.5 feet up in an open space). The trunk install is undergoing a boatload of testing, the *current* box is doing a 145.0 at 35hz with one 15, the loudest box so far farted out a 148.9 @ 58hz - if I can get this 145 @ 35hz to peak up high (hard to do, due to the unusual design - see pics) this one 15 will be in the 50's.
    Last year competed in my 99 monte carlo daily driver, this year (if I can get a few favorable rulings) I'll probably be competing in my 77 k5.
    pics :)
    wall in the MC, this is just one of many
    another
    half wall - the plan was a loud daily driver... that went down the tubes quick when i caught the comp bug!
    Current trunk, just took one battery out and moved things around a bit - there is no front battery.
    the way it was
    wow, the trunk actually closes!?!?!
    One of the boxes, with the 2 15's and 2 700 watt amps, it did a 149.5... with one 15 in a smaller box (pic'd below) it did a 148.9 with 700 watts. Now I have one 15 in this box doing a 145 @ 35hz - assuming I can get the note higher and effeciantly make use of everything... it should be in the 50's with just the one 15 and approx 1000 watts, as soon as I get my 16 volt alt :)
    another of the boxes, outside of the car
    And.... the car's exterior, next to the k5.
    I hope to compete in the same class (s1) in the k5, it will be 100x easier to work on.. and overall a heck of alot cooler - not to mention its about 4x the cargo space I have now + the hatchback advantage, which makes up for the big cabin size gain (more cabin of course = harder to get loud).
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Looks like Cerwin Vega Strokers. Good subs. I prefer the Treo Enginering myself. www.treoonline.com
  3. Spkrman
    Jan 23, 2005
    39
    Matteson, IL
    yeps... very effeciant woofers, sound like rancid but juice - but they get loud. like 8mm linear xmax, so tuning low just isn't gonna happen... when you tune a stroker low, you have to be *very* careful because they can go back quick... particularly since there is no pole/perimeter venting.
    Treo on the other hand, is known for being very ineffeciant, more of a daily driver sub... the big dog, CSX is it? is a waste of a woof... so heavy that its just not worth it anymore - takes WAY too much power to get em goin.
    Either way... its all install... but I'll take DD all day, hold more world records than any other sub :D
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    DD's are very nice. I got into the Treo's because I know a couple of guys that designed them. I plan on a pair of the 12.22 SSI's for the daily driver. I'm still kind of "old school" when it comes to amps. I have a MMATS D200hc , not the most powerfull amp, ( 1500watts at 1 ohms ) but it works for me. Currently I've only got a single 12" Kicker L7 in a large slot port box in the daily driver, but I'm planning on those Treo's by fall. For the Head unit, I'm running a Clarion DXZ945MP, and the main speakers will be Infinity Kappa's. I don't compete, but for just a daily driver, it sounds pretty good. By the way, here's a pic of the daily driver. [​IMG] [​IMG] [​IMG] [​IMG]
  5. Spkrman
    Jan 23, 2005
    39
    Matteson, IL
    d200's are no joke ;) THey are some sweet amps, as is all mmats stuff.
    as far as sub choice - whatever floats ure boat... if you were just going for loud, I'd stick with the l7's.
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Old Setup in my DD: 2 Digital Designs 9515's, Zapco C2K9.0XD :saweet: Took the setup out when I started to lose hearing.
  7. Spkrman
    Jan 23, 2005
    39
    Matteson, IL
    lol... ouch
    i hope you competed with that :)
  8. riggz
    riggz Registered Member
    Feb 9, 2005
    85
    Roswell, GA
    im running 1 12" Eclipse 88120 aluminum in a sealed box w a Kenwood x811d amp in my 02 Nissan Frontier KC. Also have the kenwood dvd/navigation head unit double din. quite nice :) (also its my DD so it gets good use)
  9. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    I used to run 2 DD9515's with 2 Cadence H7HC monoblocks, had a 260 amp alt with 2 orbital deep cycles.. loudest i ever hit was 153 @ about 50 or so hz.. I drove a 91 t-bird with a licence plate that had "play it till it hertz" Man i miss those days, the tranny went out in the car and decided to sell it, then bought a truck and sold all my stereo stuff for truck stuff.. wish i had a scanner i could show you pics of my old equipt.
  10. JIMMY76
    JIMMY76 1/2 ton status
    Dec 28, 2004
    209
    HAUGHTON,LA
    I HAVE 4 L7 12" OLD BLACK STYLE IN A MEDIUM TO BIG RECTANGLER PORTED BOX ON ABOUT 2200WATTS DONT KNOW WHAT IM HITTING AT BUT I DO KNOW THE VERY SMALL CHIP IN MY WINDSHEILD NOW LOOKS LIKE A SPIDER WEB :doah: OH ITS IN A 98 YUKON
  11. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
  12. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    You might want to tell your buddy to run a spell check on his website.... :rolleyes:
    There's nothing worse than a "professional" website with spelling or grammatical problems....it really makes you wonder how much they care about their own image, or the work they do.....
    :usaflag:
  13. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    didnt catch it, what all is misspelled?
    sorry
  14. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    "RESULTS GUANTEED"
    There's probably more....but I lost interest in the site after finding the first one...
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    For audio, you can get some good info over on Termpro .
  16. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Mines real loud and clear. No exaggerated bass, no distorted highs and mids, just plain loud and clear..
    I run a pair of 12" kicker Comp vr's in a downfire enclosure powered by a Rockford Fosgate Punch 650. 2 pairs of 6x9s in the doors and the rear panels powered by a Fosgate Punch 200ix and a Pioneer head unit. Nothing competition or high end but it sounds great to me.
    A sound system is as good as your weakest link, and it also depends on the way it was installed/hooked up.
  17. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    Now whos loud?
  18. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1: :eek1:
    :haha: :rotfl: WTF! What size is that thing? Is it real? :haha:
  19. danny7139
    Jan 27, 2005
    227
    florida
    Audiobahn AWT34X 34” sub woofer $5000 Yes its real lol
  20. JIMMY76
    Dec 28, 2004
    209
    HAUGHTON,LA
    There Is No Way There Is Enough Air Space In There For That Thing
