Who's removed a leaf in the front spring pack?? **UPDATE**
Discussion in 'The Garage' started by 88K5Jimmy, Sep 24, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Who\'s removed a leaf in the front spring pack?? **UPDATE**
    I'm planning on removing the very bottom "overload" leaf on my front spring packs so it will ride a little better (hopefully). I know how to go about doing it, just wondered if anybody has had any REAL bad effects of doing this. I know it will drop the height a bit. This is also on my daily driver as well.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Who\'s removed a leaf in the front spring pack??
    How about I just send you my sagged Superlift 6"ers and you can send me your BDS's?
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    Im curious what the problem is with the BDSs. They arent a particularly stiff spring... assuming you have decent shocks, whats wrong with the way they are now? just curious. Losing the overload will cost ya a little lift... I could give ya my HD rancho 4" springs for your BDSs. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    j
  4. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Hmmm I must have coveted spings /forums/images/graemlins/thumb.gif
    It's not they are really stiff but they seem to be a little stiffer than I would prefer. I have been paying particular attention when I drive to see how much the front suspension rides compared to the rear. The rear seems to provide less bounce or recoil compared to the front. That is why I would like to play with the spring pack just a bit.
    Currently I am running ES9000's. I know losing the overload will drop my ride height just a bit but I can live with that due to the fact that I have a touch of saggy-butt.
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    weird... not running an anti-sway bar are you? what shackles are you running up front?
    j
  6. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Actually I am running the sway bar with ORD discos and ORD's shackles up front too. I've been told to ditch the swaybar but I feel it's a necessity with my DD and the highway miles it sees. I guess I could disconnect it and see what that does.....
  7. BADRED73-N-AZ
    BADRED73-N-AZ Registered Member
    Jan 26, 2002
    65
    AZ, United States
    I took out my over load and they are BDS springs but they are 52" rear srings I have up front moved 3" forward they ride very nice I also run rancho 9000 RS. on the steet I run them on 5# to help stifen things up.
  8. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    yeah, u might try runnin it a week without the sway bar (take corners a lil slow!) to see how it works. If that doesnt work for ya, I say go for it, yank a leaf. /forums/images/graemlins/thumb.gif
    j
  9. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I took out 2 springs from my front 6 inch rancho spring pack and it rides loads better and softer now. At the same time i did that i disconnected my sway bar. My truck for now is a DD that sees rare freeway time. But it drives great. ANyway need anything else let me know
  10. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    I removed my overload on my 6" lift springs to gain flex, i would never do it again. I gained the flex i was looking for, although within a year my 6" springs were closer to 4" springs. just my $.02
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Actually, thats what i was trying to do... lower it from 6 to 4 inches or even 3. and it worked some, i'd like it a little lower and i'm hoping time will fix that
  12. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Took the bottom leaf out of my front spring pack and it rides WAY better now. I can definitely tell the spring pack is freed up some now. I can barely notice a difference in ride height but I think it did lower just enough to please me. Just thought I would share.
