who's running 4" lift and a sye with non cv shaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jp0863, Nov 20, 2004.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    who\'s running 4\" lift and a sye with non cv shaft?
    i'm about to install my 4" lift and a 14 bolt rear. i installed a sye on a 241 that's also going in, which comes with 1310 cv yoke. i was thinking of installing a 1350 non-cv yoke and running a non-cv driveshaft. is this going to be too much lift to not have a cv driveshaft?
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    Re: who\'s running 4\" lift and a sye with non cv shaft?
    non cv should be fine on a 4" lift, I am running a 4" on my 90 K5, stock D/S w/slip yoke
  3. tRustyK5
    Jul 23, 2000
    36,168
    1,366
    E-town baby!
    BigDummy89K5 and I did the 241 SYE conversion on his 89 Blazer (and did the write-up on the home page)
    He runs 4" of lift without a CV shaft and says it's just fine. He did swap a 1350 yoke onto the T-case, but it required some machining to make it work.
    Rene
  4. jp0863
    Aug 15, 2004
    566
    clovis, ca
    that's what i'm looking to do. anyone know the maximum angles a 1350 joint will do?
  5. tRustyK5
    Jul 23, 2000
    36,168
    1,366
    E-town baby!
    20 degrees IIRC. The 1410 and the 1310 will both do 30 degrees though...
    Rene
  6. jp0863
    Aug 15, 2004
    566
    clovis, ca
    thanks for the info!
