Who's running a 4 spd (stick) and rear discs???
Discussion in 'The Garage' started by COCHEV, Sep 20, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Who\'s running a 4 spd (stick) and rear discs???
    lets see your e brake set up. pics would be great. i'm going to be swaping in a rear dana 60 and the e-brake cables are totaly different then the ones on my 86 truck. so i figured if i was going to have to fab up an e brake system, i might as well go disc /forums/images/graemlins/grin.gif
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Re: Who\'s running a 4 spd (stick) and rear discs???
    I'll be running High Angle Driveline's 205 E-brake when I'm done with mine. That will be the easiest and best solution for me.
  3. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    yeah, i might have to think about that. i have a 208 though. i think they make one for a 241 also with the SYE, and i'd rather have the lower low range.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you have a 6.55:1 first gear, how the hell are you ever going to tell if your low range is 2:1 or 2.72:1?
  5. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    LOL! good point. i wonder which is more readily available in the salvage yard- a 32 spline 205 with 465 adaptor or a mechanical speedo 241 that should bolt right up to my current adapteor? anyone know?
  6. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    both are fairly rare, but you'll have better luck finding the 241.
  7. 85BlazerFan
    85BlazerFan Registered Member
    Dec 2, 2002
    14
    Audubon, NJ
    I'm in the process of finishing up my 14b FF with the disc brake conversion in my 85 K5. I'm using '77 Cadillac calipers, so when I was pulling my 10b, I pulled the drums off to gain access to the e-brake lever, disconnected the cable and pulled it through the backing plate. My point being.... I'm basically going to use my existing e-brake cables for my new rear brakes. The only thing I need to do is fabricate a mounting bracket for the cables which I'll attach to the caliper brackets.
    I should be welding the e-brake brackets in the next couple days, so I'll post some pics.
  8. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    cool, i'd like to see pics when you are done. my rig has the ebrake system that is all on the drivers side and the passenger side drum has the super long cable that reaches over to the drivers side bracket. i think weather i keep the 60 drums or go disc, i will have to put the older style set up on with the even cables and the big hoop cable that loops to both sides. sounds like a PIA to me /forums/images/graemlins/tongue.gif
  9. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    when you're in low range, granny gear is almost a joke except in very few situations. What do you think people only wheel in granny gear? What about the rest of the gears which are all of normal ratio's?
    2:1 vs 2.72:1 is like 3 times more prominent than going from 3.73's to 4.10's in the axles, and its even considerably more prominent than going from 3.73 to 4.56!
    so would you say "how are you going to tell if you have 3.08's or 4.10's if you're in low range anyway?" no.
    thats my two cents worth. Then again I think 2:1 low range is fine to begin with. your rationale is just ass backwards sometimes, IMHO. /forums/images/graemlins/confused.gif
  10. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    my last 2 rigs both had th350s. one had a 203 and one had a 208. with the auto i could tell the difference for sure. with my current rig i have the 4sp and 3.08s and 33s. i've only wheeled a little in it but in low range, 1st gear was insainly looooow. i think with that grannie gear you can get away with a little less low range.
    sort of getting back on topic here /forums/images/graemlins/grin.gif i still think i would lean towards a 241 if i could get one. i like being able to shift in to 4 hi on the fly, its is light, it will bolt right to my current adaptor, i can get a SYE and a t case e brake.
  11. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    The 241 you want is no different than any other manually selectable t-case. The only way it can be shifted into 4-HI on the fly is if the front hubs are engaged. It's the same for 208's and 205's, and I'm pretty sure 203's.
    The only way to get Shift on the Fly in the 241 without some sort of hub engaged is if you have a 88 and up IFS truck with the vacuum disconnect front diff.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mike Reeh,
    You have no idea what compression braking is anyway, since you've never experienced it. When you do, let me know.
  13. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    with the hubs in and in 2 hi, i'm pretty sure you have to stop to put it 4 hi with a 205. all the chain drive cases you can shift back and forth between 2 hi and 4 hi once the hubs are in.
    i could be wrong though /forums/images/graemlins/grin.gif
  14. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    you may be right. to me, in theory, if the front output is turning at the same speed as the rear, then it shouldn't be a problem. i could be wrong as well though.
    i guess i need to actually drive on a 205 before i talk about it.
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I always shift my 205 from 2HI to 4HI while moving (on the fly)
    Anyways, I do have a 4 speed and rear disc's. No E-brake though.
    rene
  16. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    see, i stand corrected. /forums/images/graemlins/grin.gif
    rene, is it a pain not having an e brake? i would think on the trail it might not be good having to restart on a hill or something. any feedback?
    what are you planning on doing for an e brake?
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's what granny gear is for. I don't have an e brake either. No need for it.
  18. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I just leave it in gear. The only place it can be a pain is on the trail..but the 6.2 flashes up so easily when warm it's pretty well a non-issue. In first gear and low range it'll start in gear in the steepest terrain...
    It is not legal though, so eventually I will break down and get the caddy calipers and do it up right.
    For daily driving it isn't a big deal at all. Previous to the rear disc's I rarely if ever had an E-brake that would hold the truck anyways.
    Rene
  19. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i have four wheel disk and 205.no ebrake cable yet but do have cadi calipers.my 205 i can be going over 5 or 10 mph and shift into 4 high.the gears dont catch right any faster than that.
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't really miss my E brake. I just leave it in gear. I don't trust an E brake anyway.
