who's running a stak4x4 3 spd?
Discussion in 'The Garage' started by jp0863, Jul 15, 2006.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    i am debating between an atlas 5.0 for $2636 with the adapter, or a stak 3spd for $2775 with no adapter, but delivery. the atlas i could pick up so there is no delivery charge. my only concern is that i dont know enough about the stak4x4 box. i dont know anyone who has one to ask questions, so here it is?? has anyone experienced any problems either during install or after the fact? i am leaning toward the stak box just because it looks like a good product with an extra speed over the atlas for only a couple hundred more. if you have one, what tranny are you using and did you need the adapter? the other thing that concerns me is that nobody can tell me if i need the adapter or not? i have a th400, with the atlas i need the adapter, but with the stak4x4 box, i may need the adapter and an output shaft on the tranny. nobody seems to know what i will need... that is the only reason i am second guessing the stak4x4 box.... noone seems to know what i need.. any advice?
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    go fot the atlas 5.0....Atlas is used by 90% of all uroc competitors for a reason.
  3. jp0863
    Aug 15, 2004
    566
    clovis, ca
    i had one before too, nice unit, kinda cool that they are only about an hour or so away.... road trip. new question... atlas 5.0 or 6.0? same price, 6 may be a little on the overkill side
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    I'd much rather have the Stak. It comes with the big outputs standard, it has bigger/beefier parts, it has 3 speeds for more versatility etc. Its pretty much the ultimate t-case from everything I have read about it.
    j
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I would get the stack it is a bigger unit all the way around atlas is plenty strong but I have seen them side by side(guts too) and if the stak is even close to the quality of the atlas it will be stronger
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i vote stakk
    wicked bitchen
  7. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    It has a 23 spline input. You need to use the dana 300 adapter kit.Dan
  8. jp0863
    Aug 15, 2004
    566
    clovis, ca
    they make a 32 spline input now.. so does anyone have one that they use?
  9. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Um shouldnt your CUCV already have a 32 spline th400 and round pattern 208?
    Wouldn't the stak or atlas bolt right up?
  10. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I would go 5.0 atlas and 4.10's in the diff's.
  11. jp0863
    Aug 15, 2004
    566
    clovis, ca
    thats what i have been telling both advance and stak, but neither seems to know their own product well enough to tell me. i would think they would both bolt up since the splines are the same and the bolt pattern is the same. stak says they use the dana300 bolt pattern... well i dont have a dana 300 so no way i can tell.
  12. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    dana 300's and 208's have the same bolt pattern.
  13. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I should have my Stak 2spd in about a week.
    As for a adapter you can use a stock 208/241 adapter all you have to do is waller out one of the holes since its not a perfect 6 bolt pattern like a stak/atlas.
    If I was going to spend 3k on a case it would be the new atlas 4 spd coming out soon.
    The 2spd will fit my needs just fine, I am also going to install a manual valve bpdy so I can have the stak in low and the tranny in 2nd which will give me good wheel speed when needed:D
