Whos running oil coolers in 6.2's?
Discussion in '1982-Present GM Diesel' started by protechk5, Dec 13, 2006.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Who here is running a oil cooler in their 6.2? Im looking to get one. What are some good ones to get? What lines are you using? If I get one, I think im going to just go ahead and replace the old lines also.
  2. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    I take it that you mean an aftermarket one, not the factory in-radiator setup?
    Get the biggest one that will fit. you can put it in front of the rad, just be sure to put your aux. trans cooler in front of the oil cooler if you have one.
    the rubber lines are just fine, no need to worry.
  3. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yea, haven't heard anything bad about oil cooler lines, it's the tranny cooler lines that suck!
