Who's Running RS9000's on a 6" Lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Mar 23, 2001.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Who\'s Running RS9000\'s on a 6\" Lift
    I'm installing my lift tomorrow. I need the part #'s for the RS9000's for a 6 inch lift. I haven't gotten a straight answer yet. I need some input. I'm thinkin bout going with Steve's setup in front with the Ford Shock towers and 9012's.
  2. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Re: Who\'s Running RS9000\'s on a 6\" Lift
    9012 is the part #. You can only run these up front if you do the ford shock towers.
    GOT ROCKS?
  3. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    I just ordered the shock towers, I'm picking them up tomorrow. I've decided to jus copy Steve's setup. Can I run 9012's in the rear without the custom upper shock mounts? I won't be able to weld the cross member until later. Would it damage the shocks if I run them with the stock mounts in the meantime. Is there a difference between the front and rear 9012's... are all 4 identical. Just making sure before I place the order. Thanks for the help.
  4. bigdaddy89
    May 18, 2000
    422
    Phx, Az
    You can run the 9012's in the rear without any problems. They are identical.
    GOT ROCKS?
