Whos running what?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Apr 12, 2001.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I was just curious who is running what drive trains? I have a 400, th350, np203, 10 bolt in front, 12 bolt in rear both with 3.73s, and about 28in tires
    Insurred by Smith & Wesson
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Check my sig.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  3. sluggo45acp
    sluggo45acp 1/2 ton status
    Jan 2, 2001
    472
    Northern fortress, Republic of Texas
    350/TH350/NP203, dana 44 front, 12 bolt rear, 3.07[​IMG] in both and 33-12.50 BFG M/T
    [​IMG]IF EVERYTHING WORKS IT AINT A REAL TRUCK[​IMG]
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    350 4 bolt main, SM465 4 speed, NP 205, 14 bolt FF welded 3.73's, Dana 44, 4" suspension lift, 1" ORD body lift, 36X12.5" Super Swamper TSL's....
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  5. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    Well were do i begin. Lets see right now i have stock axles. But i will soon be getting dana44 front and 14 bolt rear, Sweet. And while doing that i will get a 4" lift. Don't know what kind yet, probably go with superlift. And I am sure I will be able to run 40's no problem. I will mostly be playing in mud and at the end off next week I will be picking up my trailer. 15 ft. 10 ton trailer w/electric brakes. Ok i am done. Later LittleJimmy.....
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    305, TH700R4, NP208, 10 bolts and 31" BFG MT's [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Murphy's Laws on Life :
    "It is a mistake to allow any mechanical object to realize you are in a hurry."
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    350 4bolt sm465 np205 t-case dana 44 front 3:73 and 12bolt rear 3:73 posie
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  8. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    400ci, Th350, NP203, auto. with BFG 35" 12.50 MT's on 8"
    rims. 10 bolt front 12 bolt rear with 3.73. in the process of putting D44 in the front.
    whats a 4 letter word for farm wagon? (ford)
  9. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok... as of now... 350TBI, 700R4, NP241, 10 bolts with 3.42's.
    Hopefully in a couple months.. 12 bolt rear and D44 front with 4.10's, 4" lift and 33" tires.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  10. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    350 punched .080 over + mods, beefed up 700r4, NP205, 10 bolt front (open) and 12 bolt rear (gov loc) 4.10 gears and 33x12.50.15 BFG MT's in a '79. Work still in progress..............383 stroker
    <P ID="edit"><FONT SIZE=-1>Edited by Wheels on 04/12/01 01:01 PM (server time).</FONT></P>
  11. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Pretty stock for right this second... 87 w/ 350 TBI, 700R4, crappy 3.08 10b's... ORD steering brace, 22,000 Trans cooler, MSD Offroad Ignition, MSD Coil, K&N Filter... Just finishing up school and then it will be lift time [​IMG]!!! 6" BDS lift, rear CV shaft, 35" Pro Comp MT's, 4.10 D44 front diff and 12B rear ( later adding a Powertrax and rear discs)... also have motor plans in the future... probably a 350 w/ Vortech heads, bored out TBI unit, and custom chip...
    1987 Chevy K5 Blazer- 350 TBI
  12. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Now - TBI 350, 700-R4, NP 241, 10bolts with 3.08's [​IMG](should be against the law!!)
    When rebuilt at end of summer: TBI 383, B&M (or JET) 700-R4, NP241, and ARB'ed D60 & 14bolt both with 4.88's[​IMG]
    Brian
    89KBlazer
  13. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    On the '80 Jimmy: 350/TH350/NP205, 10B f, 12B r w/ Detroit, 4.56 gears, 4" SkyJacker Springs all around, 1.5" Superlift blocks in back, to keep things level, BFG 35x12.50-15 M/Ts on stock Rallys w/ centers & rings remover.
    On the '73 Blazer: 350/TH350/NP203 w/ part time conversion, D44 f, 12B r, 3.08 gears, homemade 4" lift-doubled & rearched front springs 4" block in back, Wild Country 33x12.50-15 M/Ts on stock white rims w/ stock hub caps.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  14. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    14-bolt FF rear w/ welded spiders, 30-spline 10-bolt front w/ Eaton Posi (may switch to locker), 4.10 gears, 6.2 diesel, 700r4, 241, 4" Skyjacker softride, ORD hd front shackles, 35x12.50 MT/R's on 15x10 8-lug steel spokes.
  15. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    350/700R4/NP208/10 bolts/33X12.50 Cheapos.
  16. KING K5
    KING K5 1/2 ton status
    Sep 28, 2000
    172
    Sacramento, Ca.
    SB-350/TH350/NP208, front D-44 w/ROCK ROD tie rod, 12 Bolt rear both w/ 4.56's and custom rear CV driveshaft. 4" Rancho springs with extra leaf and ORD H.D. shackles in front. 3.5" blocks (soon to be replaced with ORD shackle flip) and re-arched stock springs for added 2.5" of lift in rear w/ 35x14.50-15" Mickey T's soon to be 38" swampers
    Jeff
  17. lv2whl
    lv2whl 1/2 ton status
    Mar 4, 2001
    130
    CA, USA
    73 k5, 12" superlift, 2in body lift, 350ci, th350, np203, d44 and a d70 (5.13 gears), 39.5 tsl's, plus lots of other goodies.
  18. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    in my 88 350/700r4/208 10 bolt front a rear
    and in my 72
    350/sm465/203 doubler kit(still need the 203 adapter!!!! help me someone)/205 and soon to have D60 front a rear (but i have nothing at all right now)
    "Hondas look good under a k5's tires"
  19. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    1988 blazer with 6,2 diesel, 700, 10 bolts, 3 inch bodylift + 4 inch suspension 35 12,5 15 Bfg's on 10 inch rims.
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  20. Chewy
    Chewy 1/2 ton status
    Sep 4, 2000
    197
    Parker, Colorado, USA
    350 / 700R4 / NP208, 6 inch lift, 4.10 gears, 35x14.5x15 Mickey Baja's.
    '87 Beast
    Colorado, USA
