Who's runnung 44s?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Dec 18, 2001.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Who\'s runnung 44s?
    What lift and trimming did you do?
    Ken H.
    '86 K5 in parts
    14 bolt and Dana 60
    44 TSLs
    468 BBC, 350 trans, 205 transfer
    Rust free in Michigan!
  2. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Re: Who\'s runnung 44s?
    with the K5 body and 44's , we ran 8"suspension, 3" body and some good fender trimming. Even with that lift we still bashed in one fender- front drivers side
    Now with the s-10, well ....... let's just say a wee bit more [​IMG]
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  3. mnstr_fx
    mnstr_fx Registered Member
    Sep 13, 2001
    78
    IL
    6" Lift
    MAJOR fender trimming
    Front axle relocated forward 1"
    Currently 42" TSL's but there is room for 44"'s
    76-82 Chevy Pickup / Blazer - K5-K10-K30
    90' TBI
    TH 400
    203 / 205 Doubler
    Dana 60, Corp 14 - 4.88'd - Detroit Locked
  4. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Dont suppose you have pictures that would show this do you? If so, could you e-mail them to me?
    Ken H.
    '86 K5 in parts
    14 bolt and Dana 60
    44 TSLs
  5. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    You can get a higher lift so you don't hack the finders.
    Im running 44's with no fender trimming.
    15 inch springs 3 inch body.<font color=red>1 FN HI K5</font color=red>
    <a target="_blank" href=http://community.webshots.com/user/1fnhik5>http://community.webshots.com/user/1fnhik5</a>
  6. white_knight
    Feb 23, 2001
    1,171
    MOst of the pictures on this page are of the k5 on 44's
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/photo.html>http://www.whiteknight.scriptmania.com/photo.html</a>
    I'll have to look and see if I can find any more
    My computer crashed a while ago so I don't know what else is left
    nia.com
    </a>
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    White Knight...
    All I have to say to those pictures is...
    Awwww Yeah!!! Bring it on!!! Cant wait to complete it.
    I like the 8 inch springs becuase they will still moce. Unlike any higer.
    Who says a truck with 44s cant still flex!!
    Thanks a lot. If you do come across some more, let me know. Thanks again.
    Ken H.
    '86 K5 in parts
    1-ton 44 TSLs
    454 BBC, 350 trans, 205 transfer
  8. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I would rather not buy new springs. Thats $1500 I could spend on a lot more needed things.
    Plus, when you go over 8 inch springs, you get a lot stiffer spring, which I dont want.
    I wheel with almost all Jeeps, I need every bit of performance from my suspension I can get. Plus, I dont want to go taller than I have to. I already dont fit in a lot of places.
    But, I do love the looks of a high lifted truck. So have some pictures of this truck?(1 FN HI K5)
    Ken H.
    '86 K5 in parts
    1-ton 44 TSLs
  9. white_knight
    Feb 23, 2001
    1,171
    You will run into driveline issues with that lift
    We broke several front driveshafts. Make sure you get that taken care of
    nia.com
    </a>
  10. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    You saying with the 8 inch, have issues?
    I know the 15 inch mentioned above will have major issues.
    Ken H.
    '86 K5 in parts
    1-ton 44 TSLs
  11. 84silverK5
    84silverK5 Registered Member
    Nov 28, 2001
    65
    Hillsboro Oregon
    i got 8inch springs, and i havent busted a front drive shaft yet... i think all you need is some small wedges for your front and rear axles, the worst thats happend to me is pop out a cap on the CV joint in the front, the u joint closest to the transfer case... this happend about 3 times, hasnt happend latley though so who knows
  12. white_knight
    Feb 23, 2001
    1,171
    The angle of the front driveshaft was steep and we broke quite a few .
    It took a some tries at getting that right front driveshaft.
    nia.com
    </a>
  13. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I wanted to go with 44's, but everybody around here said I would open a can of worms if I did!
    1 ton '87 Chevy SWB in the making!
  14. white_knight
    Feb 23, 2001
    1,171
    In a way you do.
    I mean drive angles, you need the horsepower to turn them ,gearing etc. It could add up quickly
    But.... once you go 44's... you don't want to go back
    It feels soooooo good.
    Big difference between 44's and 40's
    nia.com
    </a>
  15. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    I've often wondered if 42's wouldn't be even better since you get about the same height without the extra width. Of course you'd have ot stay with regular TSL's and not Boggers. I'd just think they'd handle better. But I've never had either so I don't have a clue.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  16. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I run 44's with a 7" lift and my front axle moved 1.5 inches forward. No driveshaft problems at all, especially with a Doubler setup. I cut the rear of the front fenders all the way back to the mounting bolt and cut off the fenderwell down past the bolts the the firewall. Also cut the lower front extention off the front fenders . <a target="_blank" href=http://www.tennessee4x4.com/rocketcity/steve_curet.htm>www.tennessee4x4.com/rocketcity/steve_curet.htm</a>
  17. white_knight
    Feb 23, 2001
    1,171
    The doubler extends your driveline- that's a good set up.
    nia.com
    </a>
  18. white_knight
    Feb 23, 2001
    1,171
    You want the width when you're getting higher.
    44"s are the only size tire that actually measure 44"
    The again 44" aren't for everyone. Depends on the kind of wheeling you like.
    nia.com
    </a>
  19. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    What would you say is the best wheel width (in a 16.5) for 44's?
    Karl
    87 3/4 ton
  20. jwduke
    Aug 25, 2001
    721
    You can get by with a 10" one, but I'd go 12" or even 14"
