who's spray painted/rattle can-d their interior pieces ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big d, May 3, 2004.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    who\'s spray painted/rattle can-d their interior pieces ?
    im in a way where i cant afford the regular vinyl interior paint, so has any one used regualar "rattle can" paint, and how did it turn out/wear ? my plans are dash pad,console, door panels, and headliner trim. i figure as long as the pieces r cleaned real well, what can it hurt ? what about primer ? i may get a dash mat in the future to protect the dash from the sun. any and all input is appreciated. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    Re: who\'s spray painted/rattle can-d their interior pieces ?
    I have though about it, but I would rather use some bedliner to keep them tough and from cracking in the sun, and also so I could armourall them.
    Remington
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I have used regular spray paint to paint the interior successfully, but the problem is in cleaning it. Make sure when you clean your interior, after a dusty trail ride, you use only water, and do not scrub on it too hard or the paint will come off.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I cleaned everything with paint thinner and shot it with some Krylon. Turned out pretty damn good...even did the visors...
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Scrubbed mine with alcohol, primer, two coats of color and three coats of clear.... it doesn't last long if you hit with anything sharp. The kick panels in my truck need repainted again, I'm on my second drivers door, but all the headliners pieces are still in good shape (6years in a DD).
    Depending on the color you want I would use the Krylon Fusion paint. It goes on plastic, metal, whatever. I think in the porject truck I'm going to use the light tan color and repaint all that stuff.
  6. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    You can get rattle cans of primer, paint & clearcoat designed for rubber, plastic & vinyl from a good auto paint / body shop supply store, Before you start, clean everything with a pre - cleaner designed for plastics and rubber. It's a lot of steps to go through, but the paint & primer need to be flexible or everything will flake off real quick.
    Tom /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I used that on my dash. The semi-gloss black. I got the dash used from 'tazz, but you cant tell now. After prepping it REAL good, I put on 3 coats of paint and 2 coats of clear. It look sBRAND NEW and has for about a year now. I plan on doing all my stuff with it. I'll have less than $25 into a "new" interior /forums/images/graemlins/thumb.gif
