Why a 2 bolt main on the ramjet 350?
Discussion in 'The Garage' started by koldsimer, Dec 31, 2005.
  1. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    So i'm probably going to be getting a crate motor this year to replace my good ole 400. The ramjet 350 seems like a good choice all things considered, I just can't figure out why they didn't put 4 bolt main caps on it? I'm sure there is a logical explanation..... I mean, damn near every chevy crate motor i've ever seen was a 4 bolt! What gives?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    2 bolt mains can reliably handle around 600hp.....so it's alright. Oh....and they're probably cheaper to make.
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Givin the choice most of us will take the 4 bolt but in reality a twobolt is just fine till you get past about 450 hp.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    4 bolt is just insurance , and for endurance . Most of us will nevr see the need from stoplight to stoplight , or from trailhead to end .
  5. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    well ovbviously if its only got 2 bolt mains it only needs two bolt mains... 4 bolts are more about insurance and hard endurance, for what you're gonna use the engine for it wont matter.
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you're that worried about it you can always disassemble the engine and have a machine shop machine it for splayed 4 bolt caps which is then stronger than a factory 4 bolt block. In all seriousness though a 4 bolt block for most of us is nothing more than bragging rights.
  7. koldsimer
    Jan 10, 2005
    1,480
    texas
    I hear everyone and really I kinda knew that it was overkill for a stock ramjet 350. It really is just bragging rights more than anything. I guess I just have a hard time understanding why they wouldn't put them in when almost every other 350 crate motor has them. Thanks for everybodys input! I'm leaning pretty strongly towards getting this motor rather than the HT383 with a q-jet.
  8. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Interestingly, the GM Goodwrench 250HP 350 long block engine sells for less than $1,300, and it has a 4-bolt main block:
    http://www.greenwoodchevy.com/engine14.htm
    The 3yr/50k warranty looks pretty good. So does that price, if someone already had an induction system, and was looking for an improvment over their tired 305 or 350 smogger engine. A cam would do it wonders, and the heads could be better, but a lot of trucks don't get wound up too tight anyway.
    If you had another $1,100 to spend (~$2,400), and you didn't like those heads, this one gets you to 330HP with help from a better cam and iron Vortecs:
    http://www.greenwoodchevy.com/engine11.htm
  9. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    Ive always wondered if my motor is a 4 bolt main, is there any way of knowing without taking it apart? Its the original 350 in my 73. Did certain years come with 4 bolts or does the year not matter?
  10. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    Actually I was talking to the parts depo at my local chey dealer, and they told me the ram jet 350 IS a 4 bolt main, and that there is a miss print in the catalog..?????????????
  11. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    The casting number of your block (back of the block, near the bellhousing flange) would probably be a good place to start, if you could run it by a real Chevy guru, or you could match that number to this table:
    http://www.nastyz28.com/sbchevy/sblock.html
    However, a small minority of those casting number blocks could have either 2 or 4 bolt mains. For example, casting 3970010 was used in cars (including some corvettes) as well as trucks, and could be drilled for 2 or 4 bolt caps. Dropping the pan would be a sure method, of course.
    Sometimes, makers gave even muscle cars iron (nodular or not) cranks, but put forged steel in some of the trucks, because FS is expected to handle low-speed lugging better.
  12. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    That wouldn't surprise me at all, considering that it's priced in the middle of a bunch of 4-bolt GMPP crate engines.
  13. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    My understanding is the only FOR SURE way to tell is drop the pan.
  14. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    so is the ram jet worth paying the extra money for ?
    I definitely like the looks of it :)
  15. koldsimer
    Jan 10, 2005
    1,480
    texas
    I can't believe that they wouldn't have corrected it... well yeah I can. Can anybody with a RJ350 verify if this is true? C'mon, you know you wanna pull your pan!
