Why all the Tough truck challangers using 2 1/2 Rock wells?
Discussion in 'The Garage' started by merace19, Mar 2, 2005.
  1. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    Why all the Tough truck challangers using 2 1/2 Rock wells? Just got my mag in and most of the trucks are running 2 1/2ton rockwells. What is the advantage to them over a 60 and 14 bolt? They have to be alot heavier and harder to find parts for. The weight is the one reason i would not want them. More mass to move and get unstuck. I use to see them every where for cheap too.
  2. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    rockwells are...
    1) cheap
    2) have 1.6" axles, which if you run high-end allow shafts are pretty damn strong.
    3) mad low gear ratio (6.72)
    4) driveshafts attach to the top of the diff, so they don't really have to be high-angle shafts unless you have some mad crazy suspension flex.
    5) the housing is pretty much indestructable. D60 fronts have been known to bend... unless you throw it out of an airplane, a rockie prolly won't.
    j
  3. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    It's the same reason why someone upgrades 1/2 ton to 1 tons. They are going to be stronger for the bigger tires & high horsepower engines:thumb:
  4. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    Is it worth the weight penalty? What do they weigh and how much does a 60 and 14 weigh?
  5. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    You know, last night just for fun I watched that "freebie" Peterson's DVD that they spammed out a couple of years ago.....I believe it was of TTC 2001? (Watson was a spotter for the Bummer team)
    I had to laugh, only 1 vehicle could even ramp 1000 during the engineering section, and there was actually a vehicle there on D44s (Cherokee?) and the Samurai was only on 38s(?) and had a 4-cylinder engine.
    My, how times have changed. :blush: It's all Rockwells and big blocks and "money-no-object" buildups now. I think they finally even gave up on the "street legal" requirement for this year.....and not a lot of things "look" like trucks anymore either.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah, heck when looking who to vote for if it didn't have a doubler or an atlas I didn't consider it.
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Rockwells are easy to find and they are cheap. A stock rockwell may be as strong as a built 60. Although you can spend a LOT of money building a Rockwell.
    I know I spent a lot of money buying and building my D60 and 14FF. I have more in my D60 than I have in both Rockwells.
    Parts are easy to find and reasonably priced, you just need to know where to look...
    The weight on a D60 is about 600 lbs iirc. The weight of a stripped down Rockwell isn't much more if any. If you loose the drum brakes, you drop about 225 lbs on the Rocky.
    Check out this place. They have lots of HD parts from Rockies.
    http://www.ouversonengineering.com/axle_products
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm really clueless when it comes to Rockwells. I know nothing about them. So let me ask a question. Do they make lockers for the Rockwells ?? What about Disc break conversion ?? Rims ?? I'd love too build another truck in the future when money isn't so tight. I'd like too go with 49" Irok's.
  9. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Lockers=Yes, but only Detroit.
    Disc Brake conversions= Yes, or since Rocky equipped rigs more often than not don't see street use, pinion brakes.
    Rims=Stazworks(only I think they changed their name) or USA 6x6 (if desperate)
    John
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    there is suppossed to be a selectable locker coming or out. USA6x6 I think has it, but who knows with them. I forget who is really making it.
  11. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    The website that DP_90 just provided shows that company provides a positive engaugment locker for the Rockies.
  12. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    yeah, someday I'd like to have a rockie equipped rig. They are just too bad ass. If you want to run 52" michelins, they are definitely the axle to have. I know some people are in love with portals these days, but check out that ouverson site... I'm not sure it gets much tougher than a 2" 50 spline 4340 axle shaft. Sure, they are spendy... but how much are D60 Superiors / CTMs? and they ain't nearly as strong...
    j
  13. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Wow, the place that builds all the aftermarket stuff for rockwell's is only 3-4 hours from me. I have a d60/14b combo already but geee........:thinking: :D
  14. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
  15. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    btw, its worth noting that when ouverson/s 2" stuff came up over on pirate someone who is tight with Sandy Cone said he'd make the same size/spline shafts out of 300m for the same price... which might mean he'd make 4340 ones for a bit less than ouverson. 300m 2" shafts is just silly... beyond beef. I doubt even 53" michelins, 1000 ft/lbs of torque and maniacal use of the skinny pedal could break them. Something else would let go first.
    j
  16. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Oh, and another benefit is ground clearence!
