why am I killing my U-Joints?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Mar 5, 2002.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    Why does my 90 K5 eat up U-Joints, only a 1/2" add a leaf in the rear, yet I have had to replace front and rear (on the rear drive shaft) already in a 4 month period. The ones I'm buying are called "Brute Force" and come with a lifetime warranty, too bad the warranty doesn't cover my labor. Any ideas on what is the cause? Thanks guys.... 8YERCJ<----get this plate for your K5!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My first thought would be a bent/twisted driveshaft - or the axle pumpkin centerline being off in relation to the transfercase centerline (U-joints don't really like compound angles). I've also never heard of "Brute Force" 'joints - maybe try Dana/Spicer replacements?
  3. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I have heard of Brute Force and have used them. I was pleased with them.
    Held up behind a 454 and 35 inch boggers.
    Not sure on your problem though... (trying not to insult here, but...) Are you sure you installed them correctly?
    Ken H.
  4. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    After you install them do you fill them with grease (assuming they have the zerk fitting)? Also do they rotate freely once installed? I know that after I press the caps into the yoke I have hit the cross in order to push the caps out slightly on the yoke to make it move freely. Just a thought.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I think that Rampage has most likely hit on the answer. Many times the caps are pressing against the end of the cross after the u-joint has been pressed (or pounded /forums/images/icons/shocked.gif ) into place. You need to make sure that the caps are pressed back against the retaining clips, so that the u-joint moves very freely. Otherwise the caps will overheat and burn the grease. Then you're soon feeling that oh-too-familiar vibration. /forums/images/icons/mad.gif
  6. Grim-Reaper
    7,385
    Atlanta
    I'm running brutes and haven't had one fail yet.
    Only a few things I can think of that would cause that failure so quick.
    1st being the driveshaft is bottoming out. You sure you have enough travel in it?
    2nd being bent or out of phase drive shaft. ALL Drive shafts vibrate PERIOD. The only exception is if the u-joints are at a zero degree operating angle. The design of a drive shaft causes the vibration to cancel out so that it is not transmitted to the drivtrain where you would feel it. This is accomplished by "Phasing" the u-joints. The joints are phased 180 degrees of each other. So when the one joint begins to Oscillate the joint on the other end of the shaft oscilates 180 degres out of phase and it cancels out any vibration that would be transmitted.
    Now a few way's this gets out of whack is the angle on one end of the shaft is not close to the same as the other. On a drive shaft with a slip shaft you can put the shaft together out of phase if you ever slide it appart at the splines. Your 90 came with a one peice driveshaft so unless you have gone to a fixed yoke that shouldn't be an issue.
    Did you install a degree shim when you put in the add-a-leaf? Are you have some vibration problems?
    Any dents in the drive shaft?
    Take a straight edge and make sure the driveshaft is not warped.
    I have also heard of people with slip yoke shafts like the one that would have come on your truck, having the splines wear on the transmission aned and the shaft will bind as a result. THis can cause u-joint failure also.
