Why are Body Bushing's so damn expensive?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Apr 1, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Why are Body Bushing\'s so damn expensive?
    I called Rocky Mountain Suspension for a body mount kit for my 84 K5,and I was quoted $91 bones. Anybody get them for cheaper?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: Why are Body Bushing\'s so damn expensive?
    summit is priced at $54 with bolts and washers
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    Part # ENS-3-4118G <a target="_blank" href=http://store.summitracing.com/default.asp?target=search.asp%3FType%3Dbykeyword%26Part%3DBody%20mounts%26Search.x%3D1%26SearchType%3DBoth> $76.69 </a> Are these the ones I need? Also why are there ones priced for $56? What's the diff?
  4. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    Hard rubber hockey pucks are about $0.99 at the sporting goods store, drilling a 1/2" hole is free assuming you have a drill and a bit, and appropriate Grade 5 or Grade 8 bolts will run about $1.50 each with the washer included. Just stack the hockey pucks up to the appropriate height and coat the bolt with anti-seize in case you have to replace the pucks in the future. I have two older Chevys I've done this to.
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    ENS- 3 -4103 then r for red and b for black.
    $54.95 depends on the year this one says 73 to 80, so I'll have to check the one you found.
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Yeah you'll need the one you found, atleast it isn't listed as being back ordered,LOL
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Okay and are body bushings in 1" incraments? I have heard of people using the pucks for a body LIFT but not as body bushings. I have also heard of them cracking from the force.
  8. UseYourBlinker
    Jun 7, 2000
    11,117
    Thanks Jeremy... I noticed alot of parts on Summit are backordered. B/O /forums/images/icons/wink.gif
  9. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Unless your looking for death and or problems I wouldn't ever go the hocky puck route or stack any kind of lift. But it's off subject anyway the post if for body bushings.
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Mines B/O, I wonder how far out they are.
  11. UseYourBlinker
    Jun 7, 2000
    11,117
    Well broke down and went ahead and ordered a set from Summit....with shipping and handling it was $84.64 I should recieve them by Friday.
  12. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Be carefull if you buy poly mounts. Energy Suspension makes you reuse the metal inner sleeves from your original mounts. Don't know about you guys on the west coast but back east those sleeves are gonna be rusted to sh*t and you can't just buy the sleeves from the dealer. Called Energy Suspension about it and they just said to use the originals. Had to make some using stainless pipe cut in half the long way and welded to another piece of pipe to make the oval shape the sleeve has. Just a heads up, ask before you buy.
  13. UseYourBlinker
    Jun 7, 2000
    11,117
    The sleeves are included in the kit...but thanks for the heads up!!
  14. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Urethane is usally charged by the gram so bigger bushings are more expensive. I find it hard to believe Summit can sell the same parts that much cheaper than rocky mtn or us. Some cheaper is always the case with larger suppliers but $30 on a $85 part? Sounds like we're not comparing apples and apples somehow.
  15. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    You CAN buy "JUST THE SLEEVES" new! /forums/images/icons/smile.gif I got them at the local GM dealer for $15 each. The only thing is they're for a Lumina!!
    I don't have the part # here but I'll dig out my bill tonight &amp; post it. The "proper" ones for the Blazer at the delaership have the new rubber molded onto them but there's ones there for a lumina which are the identical steel shell without the rubber. I've got them installed on ym Daystar bushings that I got from ORD &amp; they're a perfect fit! /forums/images/icons/smile.gif
  16. Brian 89KBlazer
    779
    Ontario, Canada
    Re: Why are Body Bushing\'s so damn expensive?.......Part #
    Just dug out the receipt for the body mount sleeves.
    The part # is 14087857
    $9.63 GM List price
    $7.22 GM Wholesale Price
    $5.78 GM Parts Direct price
    Like I said, they're actually for a Lumina I think but they're an exact fit. I'm using them &amp; they fit fine.
  17. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> For that matter , why are tires , rims , lifts , etc. so expensive ! I mean come on ....... some of this stuff should be a bit more affordable.
  18. smartpatrol
    smartpatrol Registered Member
    Feb 6, 2002
    86
    Ault CO
    why don't you just go with the ORD 1" body lift? they start at $70 i think.
