Why are Slip yokes so bad?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bullet, Sep 4, 2002.
  1. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    I have the 241 T Case on my 90 Jimmy and was wondering why slip yokes are so bad. I know that if you pop a rear DS u-joint and that if you pull it you will lose ATF. But other than that what are so bad about them? Just trying to wiegh out the pros and cons about a SYE kit, thanks for any help.
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a 205 swap is the best SYE kit on the market
    but
    if it isnt broke dont fix it
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hell yeah! Been there, done that.
  4. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    That is the main concern. Loosing all the fluid.
    Ken H.
  5. Grim-Reaper
    7,385
    Atlanta
    In a stock aplication they are not really bad at all. They save weight and less parts involved. For a lifted 4x4 is where the problems strart making it worth the change.
    With a slip shaft and fixed yoke when the suspension cycles the slip shaft is in direct line and collapses easy.
    On a slip yoke as the drive line angle becomes more severe with a lift then the slip yoke will start binding because your not pushing inline with the way it travels.
    Then there is the issue of busting up a rear shaft and no seal on the case if you have to run without it.
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    They also shorten your driveshaft a little, which makes the angles worse.
  7. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    why? i agree the 205 is a strong case but i wouldn't swap my 241 for a 205, i like having a low range.
  8. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I'm pretty sure all of the 205 have low range. At least mine does. Anyone out there have a 205 with no low?
    Eric M.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    for starters you can get a 'never break' 205 for the price of a SYE kit ~$350
    low range isnt that different, you are giving up a ton of reliability for a 3/4 point
    as I origonally posted if it isnt broke dont fix it.
  10. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Something I haven't seen touched on in this post is the possibility of the driveshaft slip yoke "botttoming out" into the t-case. A friend of mine pushed his slip yoke rear drive shaft right into (and almost throught) the t-case on his J**P and it basically shattered the whole thing. Although I have never seen this on a slip yoke GM, I don't see why it couldn't. Just another possibility. Lance
  11. muddysub
    Jun 23, 2001
    10,451
    489
    it's hardly low, not even 2:1. know it's the strongest out there, but until 3:1s come down in price, i'll keep my 241.
    oh and i've 'never broke' my 241.
  12. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Good answer Grim. 64k question: how much angle is too much? It seems to follow that the further you pull the slip yoke out the more it will tend to slightly cock and the worse the binding will be. Guess a sloppy yoke would be even worse yet.
    Hate seeing that seal reason always brought up though. Running without a shaft is no problem, cheap plastic trans plug or home made plug and some duct tape works fine and is easy to keep in the trail box. Drove around a week like that waiting for the shaft to be made.
  13. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    [/ QUOTE ] id give up 1.96 for 2:1 /forums/images/icons/smile.gif
    and why bother with an sye? just get the right 205 not all of em came with slip yokes....specially the '72 variety
  14. jimmy88
    Feb 17, 2002
    351
    Detroit, MI area
    Agree with "if it ain't broke don't fix it".
    If the 3/4 point isn't a big deal then why would anyone pay $700 for 3:1 gears (just over 1 point) for the 205? That makes the 3/4 point worth $500.
  15. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Ley me count the ways they are bad...
    Broke 2 of them in less then 8 months..
  16. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Now how exactly did you do that again? /forums/images/icons/grin.gif
  17. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    OK, OK one was my fault.. But the other one wasn't... /forums/images/icons/smirk.gif
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the only reason I could see buying the 3:1 set is to add to a doubler
  19. Grim-Reaper
    7,385
    Atlanta
    JESSE/DRIVELINEMAN! Your help needed!
    You know that's a good question. Let's see if Jesse see's this as can give us a good answer.
  20. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    Re: JESSE/DRIVELINEMAN! Your help needed!
    Thanks for all of y'alls opinion's, its just that I cant make my mind up if that slip yokes are that bad. I mainly do mud and trails. The only rocks the Jimmy will ever see will be any runs to The Slab or Mason, or maybe even Moab next year /forums/images/icons/cool.gif My rig is flexy, no doubt in my mind, last offroading trip where I blew the 350, I rubbed the 37's in the rear inner fenderwell /forums/images/icons/ooo.gif And it seems thats where the SY weaknes's is. I really dont plan to swap a 205 becasue i dont want to bother with adapters, VSS cables and shifter modifications. I have never had a problem with the 241 (knock on wood) so I plan to keep it, hell they even make a 4:1 kit for it if I wanted to crawl that bad. Steve ran a SY 241 for a long time and look at some of the trials he ran, Moab, Powerhouseetc... and he had no problems that I know of...
