Why are the rear axle housings narrower ?
Discussion in 'The Garage' started by MOLON LABE, Nov 2, 2005.
  1. MOLON LABE
    MOLON LABE Registered Member
    Apr 15, 2005
    28
    Arizona
    Why are the rear axle housings narrower than the fronts ? Or is it that the fronts are wider ?
    I see there are spacers available to correct this, is this for looks only or is there another benefit ?
  2. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    Quite a while back, I watched a program that stated there is better stability with the front track slightly wider than the rear track.
    Do know if it is true, and if so, to what degree.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    IIRC it helps the turn radius.
  4. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    exactly correct. the truck will turn in a smaller circle this way.
  5. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    i always wondered that too... now it makes sense
  6. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    another reason for the front being wider might be that it has alot more weight to hold. wider means more stable. that and turning raduis seem to make the most sense.
  7. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Yah its for turning radius, thats why it really cracks me up when you see wheelers who want a tighter turning radius will got out of their way to widen out their rear axles to "fix" the "problem" the factory apparantly never noticed :haha:
  8. JanneB
    JanneB Registered Member Premium Member
    Dec 9, 2004
    62
    5
    Finland
    :confused: Ok I am stupid but please explaine how it makes the turning radius smaller. I just do not get it?
  9. stano
    stano 1/2 ton status
    Jan 24, 2005
    130
    Iowa
    I not sure, but is it because the front is made by spicer and the rear by GM
  10. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    Tracking, the outside wheel doesn't have to travle as far. Take a compass and draw a circle. Then open it up a little. The larger circle will have area in it.
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I have 1" spacers on the rear beause I have a 14bolt and wanted to stay 6lug. My truck dident track or turn any better before or after, It looks a lot better IMO and does cover my bedsides with alot more mud
  12. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    Whats up with my weirdo set up :confused: ?
    When I changed from 12 bolt to 14bff my width became the same.
    I thought it was just a 1/2 ton thing.
    Or did I get a hold of a super special full width 14bff for $100????
  13. muddyblzr
    Nov 2, 2004
    623
    sounds like you got a van width, there about 3'' wider overall.
  14. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I run rear wheel spacers on a conventional 14BFF, and the ORD Highsteer arms on a front D60. My turning radius is INSANELY good....I didn't pull out or mess with those steering stop bolts either. My wheels are a standard 3.75" BS Wagon Wheel...so no real magic there. I never figured out what my actual scrub radius is, but I can make U-turns into the "inner" lane as I go around the divider at the stoplight.
    Pretty impressive for such a large vehicle.
    :usaflag:
  15. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Well a K5 has inherently good turning radius because of the short wheelbase. Of course, they put the same rear ends in Subs and extended cabs, which are probably the vehicles they were actually worried about.
  16. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    It makes it easier to clear cones when rock racing.;)
  17. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    think of a backwards tricycle
  18. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    So what's your point?
  19. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Sorry to "but-in".... but I was discussing this w/ colbystephens on another thread....
    Just so I understand, are you saying that a more narrow track rear axle allows a tighter turning radius?
    I can't agree w/ this.... Please educate me.
    Here's a diagram showing a theoretical turning radius.
    I can't see how the width of the rear axle would affect it.
    Marv
  20. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Your picture makes sense, but it does not account for friction and drive motion vectors (not sure if that is the correct term though)
    I think it has to do with rear tire scrub and leverage. The rear axle is a fixed unit (i.e. the rear wheels track one direction...front to back). If they were mounted on casters and the front wheels were driving the vehicle, it wouldn't matter how wide the rear axle was because the front wheels would travel in there natural path and the rear would follow. Because the rear axles drive the vehicle forward and have to travel a wider arch with a wider axle there is more resistance and leverage of forward motion. I didn't believe it at first, but have seen it demonstrated with r/c vehicles. (same chassis, front end, etc., but swapped in different rear ends with the same gearing and tires size, just different widths). One thing I saw is that it took a noticeable difference in width to change the amount of turning radius, so a few inches on a real life vehicle wouldn't seem to make much sense, but someone hypothesized that it had to do with the difference in weight (the vehicle was scale size, but not scale weight) allowing the tires to slip more.
    This is by NO means a scientific test, but I did see it with my own eyes. It does oddly make sense that as the wheels move toward the center of the vehicle that they would push the vehicle in the intended arch of the front wheels, but the furthur out they became they would leverage against the turning motion of the front wheels.
    I would ASSume it's much like pushing a shopping cart. If you push it forward then turn slightly the cart will turn. If you push in the middle it will continue to turn a short while until it straightens out. If you push on the outside of one of the handles the cart will tend to turn to the opposite side. The furthur out to one side of the handle you push the quicker it will turn the other way. I'm assuming a wider rear tire acts the same way. When taking a left turn, the left rear tire is trying to keep the cart straight (more pronounced with a locker/limited slip). The furthur out the wheel is, the more it fights the turning effort of the front wheel.
    Ideally (for turning), the rear wheel(s) would be dead center, but then you would lose stability (plus it would be an engineering nightmare for a rear wheel (4WD) vehicle). I'm ASSuming the engineers figured a slightly narrower rear (even if marginably smaller) would yeild a slightly better turning radius without giving up much stability.
    In a vehicle that is going to be seeing heavy loads (i.e. dually pickup or cargo van), they were more concerned with safety/stability than parking lot turning radius therefore a wider rear end.
    Maybe somebody who know a heck of alot more than I, can chime in and prove/disprove this theory.
    AGAIN, I AM NO EXPERT ON THE SUBJECT, SO TAKE WHAT I SAY AND HAVE SEEN WITH A GRAIN OF SALT...
