Why can't a lunchbox locker go in a Gov-lock carrier?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blue85, Mar 14, 2003.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    Why can\'t a lunchbox locker go in a Gov-lock carrier?
    It sounds dumb, but I'm having a hard time visualizing what prevents this from working. The axleshafts are in the same place. Is the distance from the top to the bottom different so that the cross-shaft is longer?
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Re: Why can\'t a lunchbox locker go in a Gov-lock carrier?
    Educated guess here, I'm no expert:
    Lunchbox lockers are designed to replace the spider gears in a regular (open diff carrier). The carrier is designed for spider gears.
    In a LSD differential there are clutches packs along with spider gears or similar assembly. Due to more/different components, the carrier is designed differently to account for this. Therefor what fits one will not fit the other.
    I'm assuming since LSD's work OK (as long as they aren't worn out), the aftermarket "added traction" industry targeted the open differential arena to market their products (as those would be the most in need), so that is what they designed them to fit (I also believe, but could be wrong, that there are more open diff carriers out there than LSD one).
  3. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    I haven't researched it but I heard somewhere that there is a Detroit Locker (or maybe some other locker) on the market that will fit the Gov Lock carrier now.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Depending on what axle you have, there ARE lunchbox lockers that fit in a stock limited slip carrier. You just have to make sure you order the correct one.
  5. Blue85
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    I understand that. I guess I am just trying to figure out which dimesions of the carrier are different that necessitate a different design. And I wonder what would happen if you did put a locker designed for an open carrier in a gov-lock carrier. Would it be able to move all around or not fit at all or what?
  6. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    The Pinion shaft pushes the inner toothed piece out against the outer toothed piece thats attached to the axel shaft and that gets shoved against the carrier,sandwiching it all, but the lsd carriers are machined differently to accept all the cluches so the distance across the inside of the carrier is different, and if you did stick a lunchbox locker in a lsd carrier , it wouldn't work because it would have to much room between all the pieces, Am i making sense? [carrierside] too much room [ouside piece][inside piece][pinionshaft][inside piece][outside piece]too much room[carrierside]
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It wouldn't fit. The dimensions are different. It would not fit at all.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    How about a make it self-evident? /forums/images/graemlins/thumb.gif
    Gov-Lock:
    Open:
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Powertrax has lunchbox lockers that will fit many limited slip cases. But they cost over $400, so what's the point? Might as well get a Detroit Locker that is much less likely to ever break. /forums/images/graemlins/thumb.gif
  10. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    I don't think the Gov-Lock (actually the Eaton Positive Locking Differential) can be considered an LSD. An LSD is a TSTAD (Torque Sensitive Traction Adding Device) where the Gov-Lock does in fact lock both axles together making it a SSTAD (Speed Sensitive). This happens when one wheel is found to be spinning >100rpm's faster than the other while still under 20mph.
  11. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    what type axle are you talking about. The 14 bolt would have obvious reasons for not working. but for the 10, i'll be interested to hear what someone has to say...
  12. Blue85
    Jul 26, 2000
    9,088
    488
    Grand Rapids area
    I run a 14B S/F with a Gov-Lock. I've never seen an aftermarket diff that fits in there, just whole-carrier ones. If/When the day comes to replace this diff, it will probably be with a full carrier unit anyway. I had good success setting up my gears in the front diff, so this would give me experience setting up used gears.
    I'm not thinking about trying to stick a Lock-Right in my axle, I'm just trying to figure out what's different and how many places these insertable lockers push against.
    Thanks for all the responses so far. The 14B FF issue seems cut and dry!
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got a 14 bolt SF with a Gov-Loc too. I'm just going to weld it.
