Why cant I find dual 120 amp guages for my alt...?
Discussion in 'The Garage' started by uglychevyZZ4, Jan 12, 2003.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    This bites, I have dual 120 amp alternators ( your welcome mike /forums/images/graemlins/grin.gif ) and cannot find guages that go over 60 or 90, and this blows, besides that would look sweet, you know 2 side by side, at 120 amps /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/thumb.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well, umm, actually they wouldn't be showing 120 amps.... Unless you have a small city plugged into your cig lighter /forums/images/graemlins/smirk.gif. During normal operations your probably only pulling around 60 amps or so.
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    actually around 45-50, but I wanna se her light up when i hit the juice and also wanna know what Im pullin on one of em when I winch so I know when im really askin for the breaking point. /forums/images/graemlins/wink.gif
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Go to a place that sells parts for semi's. Their guages go up to that range, some are like 160 amps.
    John
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you'll notice, none of the newer vehicles even have an ammeter. They figured out that running all that current up to the dash, through a meter and then finally out to the rest of the vehicle wasn't really a great idea. Problem number one was that a short in that circuit could set the vehicle on fire. Problem number two was that when the gauge failed, the battery would no longer charge. /forums/images/graemlins/frown.gif That's why you now see voltmeters instead. As long as the voltmeter reads in the 13.5-14 volt range, all is well. If it drops below that range, then the alternator either isn't keeping up with demand or has failed. If it goes over that range, the voltage regulator has failed.
    Most ammeters in vehicles disappeared about the time the electrical demands of the vehicles required the use of an ammeter of more than about 65 amps.
  6. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I agree with Harry...scrap the ammeters and go with voltmeters, if ya gotta have two of something.....
  7. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I have tons of those in my bottom drawer, i wanna know what my winch is askin for, i have spendy batteries and dont wanna fire start these /forums/images/graemlins/grin.gif
  8. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I had a under dash fire from my amp gauge in my 75 blazer while driving down the highway, had to dump my 66oz coke on the dash to put the fire out!
  9. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    in my luv i run and ammeter but i am going to put a volt meter in this summer when i put in the oil temp gage in a pod on the door frame! /forums/images/graemlins/cool.gif(man people will think im crazy that will make 9 gauges, 6 of em are aftermarket! /forums/images/graemlins/shocked.gif)
  10. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    The safest way to put an ammeter in is to use one that has a "sending unit" mounted under the hood. Kinda like whats used in industrial welders. The only problem is that they're usually quite expensive.
  11. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I think the only way you can get an amp meter that goes that high is like from a welder or such. Ck with grainger
    they carry alot of industrial stuff. they have some that go up to 500 amp. semi's also run volt meters.
  12. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    sweet, even if i have to use a sending unit, id like that way better than volt guage, . that would be like a 502 with no hood to show it off. /forums/images/graemlins/grin.gif
  13. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Hey Rob....
    You got pics of your dual setup? /forums/images/graemlins/ears.gif
  14. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    nah, its apart right now, have to finger out how to have my alt and york in the same space??????
