why cant i use drum brake knuckles for crossover?
Discussion in 'OffRoad Design' started by misfit, Jan 10, 2002.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    the ORD webnsite says drum brake flattops cant be used withouth modifcation. why? what mod, EXACTLY? i have access to machine tools so i might be able to remedy the problem.
  2. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    the spindle hole pattern rotation is such that the brake caliper will hit the steering arm on the knuckle. The pattern is rotated toward the front of the truck too much. to fix it you would need to re-drill the spindle or the knuckle to mount the caliper bracket farther back and down. It could probably be done with a drill press if you just layed the spindle on it, transfer punched the holes and drilled carefully.
    hope this helps
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    My truck had a drum braked Dana 44 when I first got ahold of it. I converted to disk brakes from a '74 Blazer using the original knuckles. I had a lot of brake problems until I realized the caliper was hitting the steering arm. I had to grind a little off the caliper and some off the steering arm and knuckle. The grinding was nothing that would compromise strength and it worked perfectly after that. Just my .02.
    Will
    '72 C10, originally 2WD, 6"Springs f+r, Dana 60 f+r, Lock-Right front, welded rear, 4.56s, 350, SM465, NP205, 39.5" TSLs
  4. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    center to center the holes must be rotated .5 inch to relocate the caliper correctly. do both sides, otherwise you have steering limitations as well, with the caliper hitting the yoke.
    good luck.
    MTPockets
    MAD MAX: http://community.webshots.com/user/mtpockets35
