Why can't someone make a PTO ebrake?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Nov 18, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Why can\'t someone make a PTO ebrake?
    Just wondering if there was some reason no one makes a ebrake to work off the PTO provisions on a 465 or a 205.
    Taking off the PTO covers gives great access to the gears - it just doesn't seem like it would be that hard for someone with the right equipment to do.
    And one could continue to use regular yokes instead of custom flanges.
    Anyone got some input?
    -- Mike
  2. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Re: Why can\'t someone make a PTO ebrake?
    Just dosent seem very economical. The cheapest way i can think to do something like that would be to gear drive a rotor and have a calliper on the rotor. By the time you get that done you could put it on the output shaft for alot less. However, you could make a parking break fairly easily out of it.
    sparky
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    You wouldn't need a caliper or rotor, just a piece of steel that would "wedge" between the gears to stop them from turning in either direction (similar to a Park Pawl in an automatic tranny). It would be completely mechanical so it would meet the DMV regs. Not a bad idea, now I'm curious.....
  4. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    But if you were to try to wedge that piece of metal between the gears at speed, you would have a mess in your t-case. Would work for parking situations, but not real friendly for brake failure.
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The mechanical rule about the emergency brake is so that the vehicle can be stopped in the event of a complete hydraulic failure. What you're describing is just a parking mechanism and would be useless with the vehicle in motion. Ever put an auto trans in park while the vehicle was still moving? It makes a lot of ugly noises, but it doesn't slow ya down until the vehicle is nearly stopped anyway. It also doesn't take much to just break the pawl off. It isn't designed to handle that kind of stress. /forums/images/graemlins/shocked.gif
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    you dont like the driveline ebrakes?
    I don't like having to remove my 1350 rear yoke and put on the special flange.
    I also don't want to buy a new rear driveshaft. I have a beefy non-CV HD driveshaft and like it great the way it is. Plus, it cost me enough!
    -- Mike
