Why couldn't GM do like Ford did????
Discussion in 'The Garage' started by Corey 78K5, Nov 13, 2004.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Why couldn\'t GM do like Ford did????
    Why is it that GM has like a millon ways of mounting a transfer case to a tranny and a millon spline counts /forums/images/graemlins/rolleyes.gif
    Today I sold a 78 Ford NP 205 to a friend of Mine. He has a 96 ZF 5 speed that We bolted it right up to. All that was needed was to make a small notch on the tailshaft for one of the shifter rails. There wasn't even an adapter between the tranny and transfer case. Ford got it right when they used 31 spline shafts and a round bolt patterns.
    Why don't We have it that easy /forums/images/graemlins/rolleyes.gif
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Re: Why couldn\'t GM do like Ford did????
    There are a few things that ford did better. Extended cab trucks long before chevy, high pinion front axles, divorced t-cases...
  3. Corey 78K5
    13,055
    Humboldt County, CA
    2005 trucks with Dana 50/60 strait front axels locking hubs and a t-case shifter on the floor /forums/images/graemlins/whistling.gif
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it is hard to find something that Ford didn't do better then chev
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Yeah. Having the distributor right on the front of the engine was pure genius..... /forums/images/graemlins/rolleyes.gif
  6. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    On the other hand, chevy has a much better interchange of transmission to engine block mounting. Where as ford has all kinds of different mounting patterns. If either was perfect there wouldn't be so much using of ford parts in chevy's or vice versa.
  7. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif Whaat he said!! /forums/images/graemlins/rotfl.gif
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what Chev parts do Ford guys use?
    I have never had a problem with a front mounted distributor
    seeing as Chev moved the distributor to the old flathead location, off the front of the cam, in the ?90s LT1? vettes and camaros SBC it cant be that bad of a location
    there are several kits to move the distributor on racing chevys to the front as well
    hey look it even uses a Ford style cap, better ignition is another Ford plus.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Chev bellhousings are not much better
    you have multiple transmission index sizes to play with
    the sm420 uses the car size and the sm465 uses it's own unique size
    swapping parts on a chev isn't as rosy as most make it out to be
  10. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    You mean like change every part every year,so you need production dates and parts "codes" just to get the right parts??--Or use parts from other years that arent listed for the truck from the factory(I have seen several cases of this in new trucks in the 80's)-I'm not saying GM is perfect by any means,they did pull a few boners themselves--but at least you can bolt just about any GM motor in a chevy,even the ones that dont really belong there(like caddy,pontiac,olds,buick)with a minimum of butchery--ever try to put a motor in a ford??--they might all have the same transfer case setup,but ford motors have a bunch of different bell housings,flywheels,motor mounts,etc--I stick with GM when it comes to interchangeability!--plus I still have too many spare GM parts hanging aroung to go switching brands now!.I'd go to a Mopar truck over a ford,I always liked their engines and tranny's--I see too many broken late model fords in my friends shop with low milage,and big problems.Yesterday he was installing the second Heli-Coil in a 2001 V-10 Excursion's cylinder heads--seems they only have about 4 threads to hold the spark plugs in the heads(aluminum)and they usually come out with the spark plugs!-(they blew right out of the head while driving down the interstate!)-no factory recall yet,but ford has admitted they have been troublesome--things like that sour me from buying a ford. /forums/images/graemlins/tongue.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/screwy.gif
  11. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    The one thing Chevy did better than Ford was the V8 engine.
    Chevy: Adjustable Rocker Arms
    Ford: Non-Adjustable
    Chevy: Water Pump connected directly to block with four bolts
    Ford: Connected to timing chain cover with 10 bolts (and it still leaks)
    Chevy: Oil pump connected to rear main cap with 9/16 diameter shaft
    Ford: Connected to timing chain cover with 3/8 diameter hex shaft
    Chevy: Tin steel pan Timing chain cover
    Ford: Cast iron timing chain cover
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    actually, I have put a few different Ford motors in Ford cars and trucks.
    no different then working on a chev or dodge or pontiac ...
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    which motor are you comparing??
    Fords with solid lifter cams got adjustable rockers, hydraulics do not need adjustment.
    Some Fords even came with the superior shaft rocker system (only works cheaply on inferior inline valve wedge engines)
    actually if you look at an FE engine that was designed back in the days when the Chev engine were developed you would see this is a fallicy as well
    the maincap has got to be the stupidest placement of a pump.
    Fords are bolted to the block and the distributor on every Ford V8 that I am familiar with is in the block not the timing cover
    again the old FE engines use the same system as the Chev more modern engine do not use the tin cover, just the old junk does
    in the case of the 351C the timing cover is plate steel and there is a raised section of block similar to the caddy motor.
    I have never seen a systemic leaky waterpump problem on any ford, or chev for that matter.
    Chev has had to create special motors that have never graced a production Chev to compete with Ford motors that closely resemble production engines in pretty much every North American motorsport.
    you NASCAR fans should be up on this fact.
    even the "latest" (meaning 12 year old cylinder heads that are just now made legal) Ford SC1 heads will bolt to my 351C or pretty much any sbf with a matching hiport intake manifold (and perhaps notching the pistons for valve reliefs but I am unsure if NASCAR allowed them to move the valves from stock location)
    try that with what is called a 'Chevrolet' by NASCAR
    then we can go to NHRA in the ProStock and what was ProStockTruck and compare the motors in the Chevy pits to what actually came in any Chevrolet product
    vs what was under the hoods of Fords.
    Fords dominance ended when W. Johnson was allowed to create a special motor and politics let it through the rulebook
    prior to that Mr Glidden was the winningest man in ProStock History
    I will leave TransAm out of it as I do not know where that sanctioning body has gone in regards to engines
    I do know they allowed Chev to use an 8.2 deck hieght motor to try and compete with the Fords that were basically Boss302s
    I am behind the times in all of these motorsports but the gist of it is the Chev production based motors cannot compete
  14. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    try to find a 40's ford hot rod with a ford engine and tranny in it, rare breed, and if they do have ford stuff more than likley they will have a corvette rear end
  15. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    14FF enuf' said
  16. Corey 78K5
    13,055
    Humboldt County, CA
    So how did this turn from T-case mountint to timing chain covers and oil pump locations, and what the hell does Nascar have to do with it /forums/images/graemlins/rolleyes.gif
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ford did some real intelligent things. Like...studs in the torque converter....yeah. /forums/images/graemlins/rolleyes.gif
    Not to mention the 3 engines of the same cubic inch displacement, all with different bellhousing patterns.
    Oh yeah and that 351/400M, lots of power above 3,500. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    those obviously are not "Ford guys"
    my 400 ford is going to have plenty of power /forums/images/graemlins/smile.gif
    400 problem is compression and cam, they have bigger valves and ports then any SBC factory installed
    actually 4 engines of the same displacement with 3 different bellhousings
    352FE uses the ancient FE pattern, 351W and 351C share the modern sbf pattern, and the 351M uses the modern big block pattern.
    you can get the bell with the motor when you swap and the tranny will bolt up, unlike a chev swap involving a sm465 and a car bellhousing.
    it isn't any easier or harder, just different.
    I have never had a problem with studs in the torque convertor, how has this caused you grief?
    as the origonal post states, try and swap transfer cases around in a chev and tell me again how easy swappin chev stuff is.
    just think how easy doing a doubler on a ford would be vs on a manual transmission chev.
    any 203 from a ford comes 31 spline and any 205 from a ford comes 31 spline + doubler kit. and it bolts to the round tranny adapter on all the fullsize trannys auto or manual
    vs
    a rare 1974 only 203 with weak worn out 10 spline and a rare t400 only version 32 spline 205 + doubler kit
  19. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    how about the interchangeability of most all small block Chevy motor parts? you can take anything from a 305 and put it on a 350. hell except for the crank being externally balanced on the 383 and 400 everything else interchanges. can you take anything from a ford 302 and put it on a 351?
  20. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    actually yes you can, 302 and 351W are preaty much the same block, same bore even.
    ford has some funky designs but so does chevy. like the thermostat on a ford, goes in from the front, instead of the top. still works the same, but can fall down and crack the housing when tightened. then again chevy did the same on the 4.3 vortec.
    the problem i have seen with the distributor in front is its the first thing to get wet in a mud/water hole and it kills the motor. a solution is cover the cap and wires with lithium grease and the water doesn't get in, but that sill doesn't completely solve the problem.
    i agree with the tcases, i have asked that question many times. but you still have a few problems with that, if you put a 205 in a newer truck with a slipyoke, or change a np203 with a np205 the front drive shaft is too long. you do have the same problems with a chevy but you don't have to wory about the splines.
