Why did GM use Torsen bars?
Discussion in 'The Garage' started by Pookster, Jun 13, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    So I keep thinking to myself....
    Ford uses Leaf Springs for the front axle. (250+)
    Dodge uses Coil Springs
    GM uses Torsen bars (4wd) and now using springs in the rear of their 1/2 tons.
    ok, other than "thats what they decided to do"... it would have seemed like springs (proven) woulda worked better and smoother than torsen?
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    GM has the tortion bars on their 2wds also.
    There supposed to be smoother riding.
  3. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    /forums/images/graemlins/thinking.gif Which two wheel drives ? all the FS trucks in 2wd I've seen use only coils. Though there are the random Solid front 2wd models with.. leafs...
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well since GM went to Independent front suspension, and its four wheel drive, seems to me if they used coil springs , you couldn't have an axleshaft in that space . And as for rear of the trucks, I believe only the Hummer and Tahoes etc got rear coils. Most pickups and the Colorado for sure have rear leaves /forums/images/graemlins/k5.gif
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The 2wd trucks changed to torsion bars for '99 in the re-styled Silverado/Sierra. 2wd vans changed to torsion bars for '03.
    EDIT:
    Torsion bars makes production easier. Now a 2wd is just a gutted 4x4.
    Avalanche and Suburban 1500 are rear coil as well for improved ride.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You wouldn't have an axle shaft in that exact place but that doesn't make it impossible.
    Check out a hummer H1 sometime or a HMMWV.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    For one thing, springs don't have to go in the center of the upper/lower arms. There are a variety of ways to do it, one of the most common alternatives being on top of the upper.
    T-bars are simple, inexpensive, compact, easily tune-able, and robust. They also have a natural tendency to increase rate as lever angle increases (assuming starting near horizontal) due to changes in rotational force (think component vectors) as the lever gets more vertical.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It may be possible, but those trucks you mentioned were not designed for the general public. I may not be an expert , but I do know that GM would of took the easy way out and made the trucks as cheap as they could , including R+D money, they are a business you know. /forums/images/graemlins/k5.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There are others, those are just the examples I can think of. I believe the newer toyota trucks use coils up front with IFS. I don't much care for IFS so I don't research it very much at all....but I know there are plenty of rigs on the market with a arms and coils.
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thats one of the reasons I can never a buy a new truck (for wheeling), IFS is fine for the wifes car, but not my truck. /forums/images/graemlins/waytogo.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have an IFS rig for a daily driver, but I never expect to do anything with it. /forums/images/graemlins/thumb.gif
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    The new F150s have Coil spring A arm 4wd setups. My daily driver has IFS as well, no transfer case or front diff either /forums/images/graemlins/wink.gif
  13. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    1960-62 Chevy and GMC were torsion bar front suspension on the 2wd's /forums/images/graemlins/thumb.gif Even used them all the way up to the large 2 ton and bigger trucks. Makes one heck of a smooth ride compared to leaf spring front suspensions and alot easier to package together than the coil springs on 4x4 IFS trucks.
  14. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the new dodges are torsion as well.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    1/2 tons thats correct. Durangos and Dakotas have been for a long time.
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Hummer H1 was the only truck, sonce 1972 to come with rear leaf suspension. the H2 is just built on a K2500 chassis, so nothing special there.
  17. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  18. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    EDIT:
    My 2001 Chevy regular cab shortbed has coil springs /forums/images/graemlins/thinking.gif
  19. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a coil spring is just a bent up torsion bar
    the torsion bar is the best spring design
    lowest friction loss
  20. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Dunno, my k2500 rides a lot rougher than my friends yukon XL does.
