Why did it do that?
Discussion in 'The Garage' started by stockk5, Jan 7, 2005.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Tonight i took my truck mudding for the first time since the lift kit, not anything real serious just some playing around in a frozenish field w/ trails that have ruts in them.i was bouncing around in the field over the frozen ruts and such but nothing even close to what i would consider harsh at all. My steering wasnt perfect after i did the lift, my wheel was always a lil bit sideways when it was going straight, no biggie, but as soon as i got outta the field and back onto the road, the wheel was a full 1/4 turn off of being straight when the truck drove straight, i came home, adjusted my drag link again and now its perfect. I had everything really tight before mudding, and my frame doesnt have a crack in it. Why the heck did my steering go outta wack?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Check the frame around and behind the steering box.
  3. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    ya i checked all around the steering box and what not, not a single crack anywhere.
  4. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    heat it up with a torch, if youve got cracks theyll jump right out
  5. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    :( :( :( ugh that sucks i reallly hope its not the frame i dont need that kinda head ache :(
  6. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    it wouldnt be thaaaatt bad. cut a v groove in the crack, weld in the groove, grind it flat, and weld on some of ord's frame repair kits. and its fixed. but id suggest you get a bolt in steering box brace either way. i dont have cracks in my frame, but ive got both of ord's steering braces for more beef.
  7. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    hm well i went over it really well, cleaned the frame w/ a wire brush, nothing, hmm wiiierd oh well.
  8. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    ? steering problem
    did you recheck your ubolts to make sure the axle hasnt moved. i had this happen 1 time on mine put kit in and 2 weeks later put shims in and reused ubolts . thay came loose. so never reuse old ubolts i leared the hard way. just idea to check over. good luck:cool1:
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    all ubolts need to be checked after a few miles or so, used or not. ive used new and old ubolts, both need to be retorqued after 100 miles or so.
    the springs could have settled a bit, a 1/4 turn is a bit though. mine is 1/4 turn off with the stock steering arm on without adjusting the draglink (dam rust) with my 4" lift.
  10. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    hm i did think of that, i didnt really follow through fully though, i only checked teh driver side u-bolts, they are new ones as well, ill go over everything again, should be ok then. thanks for the tips
  11. whiskey bent
    whiskey bent Registered Member
    May 24, 2004
    49
    Alabama
    Sounds like the threads are stripped out in the draglink/tierod.
