Why do headers have the collector thing and not a slip pipe?
Discussion in 'The Garage' started by sled_dog, Mar 6, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Both my collector gaskets are blown out. I was just noting that if these damn headers had say a 3" in pipe that I could slip a 3" out pipe over it would be far more efficient. No gasket needed, no leaks. When I go home at the end of march thats what I'm going to do. Redo the exhaust without collector flanges.
  2. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    i wish someone would find out more about those funky collectors that ZEPR was asking about.. the ones that were on Trucks i believe..
    i personally never had an issue with the standard 3-holes.. but i was anal about getting in there and retorqueing them the first couple weeks.. guess i got lucky...
    i eliminated it on the Chevelle by having the extended collectors welded on... they where supposed to help bottom end, so i figured i'd give em a shot...
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    extended collectors? You mean longer pipes that neck down to the size you need?
  4. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    like these..
  5. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I thought the point of having 3 hole collectors is to be able to take your exhaust on and off without having to cut or pry.
    I don't have any gaskets on my collectors and they don't leak but they are right out of the box and flowtech afterburner headers and pipe.
  6. dyeager535
    26,975
    This is why the Hedman Elites (at least) run a "standard" ball/socket design, and not the 3 bolt flat flange.
  7. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    you run a standard pipe slipped on the end with standard clamps...
    they'll be leaking shortly then... ;)
  8. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I only run one clamp, the headers bolt to the y pipe and the y pipe clamps to the cat.
    well see...
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Pick the right size and weld to your existing headers and pipes:
    Ball Flange Kits
    They're WAY easier to disassemble than a slip-fit joint. :cool1:
  10. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    ah, i swear its like pulling teeth with you... ;)
    by welding the collector to the header you are exchanging the removable joint from the leakprone 3 bolt spot for a much more leakproof pipe on pipe connection..
  11. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    wish they where available back in the day when i did the slipjoint style.. :(
    tho mine have never been a prob... :D
  12. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I don't doubt that it is better... i'm supposed to get my hands on a welder next weekend.
    I like being able to take the y pipe off without having to pull the headers... once its all up and running and i don't need to pull it off it will be welded.
  13. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    The collector gaskets usually blow out due to the bolts loosening up.
    One way to keep the bolts from loosening is to use Stage 8 locking bolts. They make kits for headers and collectors. I have my collectors welded to my Y pipe, so that's not an issue; but I used the stage 8 bolts on my headers to keep the manifold gaskets from going.
    Thomas.
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I don't use manifold gaskets, I have no issues. I run a nice bead of red RTV around each primary tube and let it sit for about 5 minutes then install them to the heads. Never had a leak this way. My dad and cousin do the samethings on their race cars. I'll never use header gaskets again(never had them not leak). Dad told me to do the same with my collectors but I think thats stupid. I'm either gonna go to ball and socket or slip joint. I know why the passenger side blows out, I messed up when I made the exhaust and the collector is on a little bit of an angle. Half of the gasket is still there on that side. But on the driveside one of the bolts is missing so thats definetally a loose bolt issue.
  15. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    why would someone have to take the header off? :confused:
  16. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    you run no header gaskets and no intake gaskets? Just red rtv?
    how long does it last?
    I might tell my mom to pick up a tube of red rtv instead of buying cigarretes when she goes to bed so i can start her up without wondering if im gonna end up with water in my oil in a week or two.
    If I weld the pipe to the headers.... you know if i decide to cut the collectors
    off.
    edit_ nevermind im a jackass..... didn't know what ball collectors are.
    How is that any better than 3 bolts?
  17. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    By slip joint do you mean when one pipe goes inside the other and then clamp them with a muffler clamp? The dimples from the clamp will make the pipe near impossible to remove. I cut my collectors off and weld my pipes directly to the headers. No leaks ever. I can't think of any reason I may have to remove my headers, or any part of my exhaust system, so easy removal is not an issue.
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah the slip joint would be an issue with the clamping. I usually expand the pipes every time I pull them apart but ball and socket may be the way to go. I need to slip
    Dirtwarrior- No I use intake gaskets, I don't think rtv would be a good choice there, though I don't use the end rubber pieces on the intakes, I just use black RTV there. Red RTV is the only thing I use for headers though, no gaskets there.
  19. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    anyone tried those soft copper header gaskets advertised in Summit? Last set of headers I had, once a month I checked all theheader bolts, always had to tighten up a few of them.Why couldn't you use a slip joint with welded on bolt tabs to hold things together? Seems like NASCAR uses something similar on their exhaust systems.
  20. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I have been running Earls Dead Soft aluminum gaskets for the past year or so. use to replace my old ones about once a month or so and the parts guys got tired of me exchanging them (gotta love lifetime warranty) and gave me a set of the aluminum ones. Were like 30 bucks I believe but work great. I will never run a regular gasket again.
