why do i keep blowing fuses?
Discussion in 'The Garage' started by colbystephens, Jul 31, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i blew my blinker fuse and my brake light fuse in one day. put in a new blinker fuse and it was blown in a matter of 20 minutes. if i put a new fuse in for my brake lights, they only stay on. i just did my 465 swap, so i'm thinking maybe i need to adjust a brake light sensor, but i can't figure out where to start on why i'm blowing blinker fuses. i'm using a 20 fuse in the blinker and a 15 in the brake...i think. does this sound like the right size fuses? any thoughts??
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Trailer harness wiring.
    That's my guess.
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i think that's a good guess. how do i handle that situation?
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Find out where the short is and fix it. More than likely is from bare wire or bad connection, i.e full of water/mud/dirt/crud.
  5. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    yeah sounds like a short to me. few months back my tail lights did the same thing. turned out to be the wire for the back up lights was cut and was shorting on the frame causing the tail light fuse to blow. wired the two together and then it quit blowing fuses as well as giving me backup lights.:D
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Check where the factory wire retention clips slide on the frame... They like to chafe the wires.. Mine did it and welded themselves into a nice little ball...
