Why do I keep blowing the brake light fuse?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Mar 6, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have a 5x8 trailer that I tow sometimes. Every time I do, I blow the fuse for the brake lights. I started by rewiring the trailer...twice. Then I looked under my truck and saw a mess of wires. The factory harness was still wrapped in tape near the tailpan. The harness that went to the trailer was spliced into it. I bought a new harness thta plugs in between the harnesses for the lights and took the old factory one out. Now the wiring is all cleaned up, and it is still blowing fuses. The grounds are connected on the truck and trailer side, and there are no splits i nthe wires thta I see. I had it in park and pushed the brake down several times and it didn't blow, but once I started moving, I soon noticed that the brake warning light was on again. I'm getting really mad at this...anyone have some ideas?
    90K5
  2. dyeager535
    26,979
    I had a similar problem. Wired up a very small trailer. Two lights, thats IT. Hooked the wiring on the truck up. (mine too, was a jumble of existing wire) I spent the time with the multimeter, making sure each wire did what it was supposed to do regarding the turn signals, brake lights, etc.
    Hook the trailer up, drive a bit, turn on headlights, bang. Blown fuse. Same thing over and over. Left it over at my dads, so he could mess with it if he wanted (retired) I come home, see him standing next to it. Asked him if he fixed it. Yes he did. How? Cut the wire I used as a ground on the truck side of the plug. All I can guess is that one wire, when the lights were on or whatever, was somehow hooked to a ground. The trailer grounds fine through the ball in my case, the lights on the trailer are grounded to the trailer frame. Just something to try I guess...
    Dorian
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It has to be a ground fault somewhere. Maybe a wire coming from the brake switch ? Maybe its the brake switch.
    creepin' and crawlin'
    Jim
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Because you have a short somewhere. Check every wire going to the trailer, and coming back from the trailer.
    <font color=blue> I'm down with the clown, till I'm dead in the ground.</font color=blue>
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It turned out being the actual light on the trailer. For some reason it wasn't working. I tried switching it out with another one I had lying around and it worked.[​IMG]
    90K5
  6. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    On some trucks the white wire is a back up light others its the ground I dont know why but check it out
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
