Why do I keep going through U joints?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Cheyenne, Aug 12, 2000.
  1. 79Cheyenne
    79Cheyenne 1/2 ton status
    Feb 19, 2000
    116
    Atlanta,GA
    this past few months I have been running through Universal joints like crazy. The front of the rear driveshaft, at the transfer case yoke has broken three times. Could there be a supplementary problem causing this or is this a common event in the life of a Blazer owner?
    also I have noticed a small amount of play at the rear carrier(I think this may have something to do with it).
    thanks in advance for help.
    <font color=orange>1979 BLAZER Cheyenne[​IMG]
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Maybe they were not greased when they were installed. Next time use Spicer U joints and make sure the needles inside have plenty of high quality grease. If you have a lift, you may have to adjust the angle of the driveshaft by either lowering your transfer case or move the perches on the axle. You could even be forced to change to CV-joints. Do you feel any vibrations when driving?
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  3. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    I don't think that it is common, at least on the later models. My '89 eats up rear u joints,(greased or not).
    The front joint in the rear driveshaft seems to last forever.
    John
    So Much to do, So LITTLE cash.
  4. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I've gone through a grand total of two U-joints in 3 years, both were rear U-joints at the diff. I don't know if it is that common on K5's to eat U-joints. I made the mistake of installing a sealed (non-greasable) U-joint the first time I had to replace one, it only lasted about 5000 miles.
    Rene 81 Jimmy,350,SM465/NP205,FF14 bolt,HD Dana 44,3.73's,4"susp.,35"Grabber MT's,body in progress
