why do I smell fuel?
Discussion in 'The Garage' started by MilpitasK5, Nov 21, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I just changed my fuel filter and sprayed my carb a little with carb cleaner. Now, it feels like it runs better but smell fuel. Even in the cab. I checked to see if fuel filter house was loose but that's not it. What else to check? /forums/images/graemlins/ears.gif
    86' K5
    5.7L
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Make sure the fuel line is not leaking at the fuel filter fitting. Since the smell is new the leak almost certainly has to be related to the recent work.
    Good luck and find it SOON. /forums/images/graemlins/shocked.gif
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    okay, thanks!
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    did you get gas all over you? /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
  5. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    not at all... I changed the filter that was on the carb so it didn't get all over the place! /forums/images/graemlins/tongue.gif
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    wash your hands...LOL, seriously though, gas fumes linger pretty well so thats probably it..leave the windows cracked overnight and see if its gone in the AM..
  7. eric22
    eric22 1/2 ton status
    Oct 10, 2003
    139
    Lemoore CA
    well mine smells like propane somtimes, /forums/images/graemlins/thinking.gif which really makes me think hmmmm
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    maybe when you sprayed w/ carb cleaner you blew apart the gasket between the manifold and the carb? Maybe some crud u blasted away was the gasket.
