Why do i smell gas in the truck??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88MudBeast, Oct 23, 2001.
  1. 88MudBeast
    88MudBeast Registered Member
    Nov 8, 2000
    67
    Dallas, TX
    OK, yesterday i filled up with regular unleaed gas, and now I smell gasoline in the truck. Its pretty thick in the back, but not quite as much in the front. Could there be some kind of leak? Thanks
    -Jake
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I would say your vent tube is ripped
    my 79 rust bucket will run over your 2001 chevy 4X4 tahoe plastic wagon
  3. 88MudBeast
    Nov 8, 2000
    67
    Dallas, TX
    And what exactly is that?
    -Jake
  4. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    Or you might want to cut down the trips to Taco Bell.
    Good lord. The rod up that man's butt must have a rod up it's butt.
  5. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Just a thought, but did you drive with your back window down? If you have never done that, it creates a vacume and sucks in all the exaust gas from the truck. Its a long shot, but that might be what you are smelling.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  6. Redfrog
    May 4, 2001
    753
    IL
    The vent tube runs along the side of the filler hose and lets the gas vapor vent outside. The one on my 76 ripped and I smelled gas. if you get the tank to full gas will come out of it also.Someone correct me if I'm wrong. Or it may be what Sparky
  7. dyeager535
    26,980
    Theres a few things that can leak in the back for fuel. Crawl under the truck and look where the fuel fill neck goes. You will see a large rubber connecting hose, and a small one. Both should still be attached at the fill neck, and the fittings that come off of the sending unit (top of tank) while you are there, try and eyeball any of the rubber fuel/vapor/return lines that enter the tank. All exit/enter the tank on the passenger side, where the fittings for the fill neck hoses go. Might have popped one, cut one, or the clamp broke. If you disconnected the EVAP cannister up front, that will let out gas fumes as well. (which is why it really shouldn't be disconnected)
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  8. Grim-Reaper
    7,385
    Atlanta
    Is the metal cover in the bed area rusted through. Could have shot some gas out and if that is rusted out the gas may have got into the carpet if it backwashed like it seems most pumps do these days.
    Women dig dents and flat paint!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  9. Grim-Reaper
    7,385
    Atlanta
    Is the metal cover in the bed area rusted through. Could have shot some gas out and if that is rusted out the gas may have got into the carpet if it backwashed like it seems most pumps do these days. burp
    75 Jimmy, Dollar
    Grim-Reaper
  10. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    I had the same problem until I replaced the rubber weatherstripping on my tailgate. I replaced it and no more gas smell. Although I have dual exhausts that exit directly under my rear bumper. I don't even think of driving with my rear window down.
    1986 K5, New GM 350, Edelbrock Intake, K&N Air Filter, Flowtech Headers, Dual 3" Exhaust, 33" Pirelli Scorpion AT, 700R4, 3.42 gears
  11. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> You may never know what your trucks rear floor is like under the carpet ......... Mine was shot and I'm sure it was letting lots of fumes in through there ........ with new floor hopefully will put an end to that ! My exhaust tips exit at the rear at a 45 degree angle so that shouldn't be an issue !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  12. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    my pipes used to exit out the side and i always had my window down, now my pipes run straight back under my bumper and i cant even crack the rear with out smelling it.
