Why do my hot water pipes sing?
Discussion in 'The Lounge' started by gotmud?, Jan 23, 2005.
  1. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    We just bought this house and when you run the hot water in the kitchen or the shower it makes kind of a sqealing noise:confused: Sometimes it will abruptly stop for a moment but then will start again. kind of annoying when you're trying to sleep and someone is using the shower:mad: Any idea's??? Thank's,Mark
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    does it have a well or city water?
  3. gotmud?
    Feb 23, 2002
    1,172
    up north
    well, pressure runs in the mid 50's
  4. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    has something to do with the rate at which the water flows through the pipes. They call it harmonics or something like that. Just get use to finding the spot that does not make the sound. Don't know how to fix it. On machine where the hydraulics do this we just tweek the orfice or other adjustment on the valves because this is not good for them.
  5. Storm Trooper
    Nov 24, 2000
    4,640
    Is it coming for just one shower valve or all over?
    You need to locate where is coming from before I could help you.
  6. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    we called them ghost pipes when we were little. STORM TROOPER is the man and HIPINION fixed my plumbing problem.:grin: :grin: :grin:
  7. gotmud?
    Feb 23, 2002
    1,172
    up north
    sounds like it's coming right from the shower head and the kitchen faucet.At least that's what it sounds like to me, changed shower heads and the little thing that screws on to the faucet, no change. Only does it at these 2 locations. sometimes it quits for a moment then starts again.
  8. Storm Trooper
    Nov 24, 2000
    4,640
    Sounds like a Toilet ballcock/fill valve or a ice maker. Does it only do it when you use one of the faucets or when they are both off? Take the lid off the toilet and turn the shower or kit. faucet on and watch the toilet tank level.
  9. gotmud?
    Feb 23, 2002
    1,172
    up north
    Wife just told me kitchen only does it when you use the sprayer and shower only does it thru the shower head not the main spout.
  10. Storm Trooper
    Nov 24, 2000
    4,640
    Kitchen sounds like the diverter in the valve for the sprayer.
    Shower sounds like it might be a water saver in the shower head or the valve just needs a rebuild. Doesn't sound like anything major.
  11. gotmud?
    Feb 23, 2002
    1,172
    up north
    kitchen sprayer is brand new and I removed the water saver in the shower head. Thank's for the reply's:DAre you talking about the diverter in the main faucets? You can rebuild them?
  12. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    They have found that the coating on the heating elements in water heaters has been braking down and going though your hot water lines (heard thsi from my ol man whos a pumber) . Did the water come out of the sink at odd angles instead of a stream did you find little white pieces in the screen from the sink? They are very small but noticable if you look. Try draining your hot water heater, Youll get alot of nasty stuff out if you havent done it recently. We just did this at our house and cleaned the screens and they havent plugged back up and the pipes have been quiet now for about 2 weeks. Its worth a shot if you dont mind a little work.
  13. Storm Trooper
    Nov 24, 2000
    4,640
    It depends on what faucet you have but all most all are replaceable. If it's a delta (kit.), you need to take it apart (after you buy the new diverter) and pull the spout off to get to it. As for the shower, it also depends on what type it is. It might be as simple as a loose washer in the diverter (if it's a tree handle valve). Pics go a long way :) .
  14. gotmud?
    Feb 23, 2002
    1,172
    up north
    both are single handle Moen.
  15. Storm Trooper
    Nov 24, 2000
    4,640
    It might be worth poping in a couple new catridges. There easy to do if there not stuck in there. It will make them work like new. If they keep singing to you and it starts to sound like a tune you know, better run like hell. :grin:
  16. gotmud?
    Feb 23, 2002
    1,172
    up north
    Thank's for all the info!:waytogo:
