Why do people install the shocks like this?
Discussion in 'The Garage' started by TX Mudder, Feb 9, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Those are the DT 8403's, just like what I am going to put on.
    Why do people put them on upside down?
    I can't figure that out.
    The other thing I can't figure out is:
    Why would they put those long travel shocks on a stock height rig? Look at the leaf springs - those are flat stockers.
    Here's the whole story.
    -- Mike
  2. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Those are stock springs after a spring over on a Jeep I think...
    Mounting them upside down helps protect the shock body from getting damaged. A lot of shocks cannot be mounted this way (my RS5000's can't)
    Rene
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    they are manufacturer-approved to run with the shock body on top or bottom... peeps prolly put them that way so that water/gunk/grime doesnt seep past the seals. Just a guess.
    j
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    who says they are up side down. i got some bilstien 1600 and will be mounted the same way.
  6. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Some shocks are manufactured to be mounted in only configuration. Most of the shocks that inhabit the off-road world are setup to be ran with the shock body on the lower portion while the open end is on top. If a shock is not setup properly according to manufacturer's suggestions, the valving will be F'ed up and your ride will be discombubalated.
  7. beater74
    May 29, 2001
    1,749
    atlanta
    yes i know all that. what i'm trying to say is many shocks can be mounted either way. just because the body is one the top dosen't mean they are up aide down.
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Sprung-over Sami. Sami's are the only rig I know of with the caliper mounted in that location.
    Mounting them like that reduces unsprung weight. Something to care about if you're going fast. Something to not worry about if you're going slow.
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Rancho 9000's can be mounted like that, and i mount mine like that to keep junk out of the seals and so that the adjuster is on the top.
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    those are DTs... if the engys at DT say they are a-ok to mount that way.. its a-ok. lets leave the engineering to the engineers! /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif
    j
  12. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    discombubalated.
    I Have not seen that word in a while /forums/images/graemlins/thumb.gif
  13. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    It's discombobulated.
    I didn't think the DT shocks were made to run either way. I've emailed the tech guys at Doetsch so we'll see what they have to say.
    -- Mike
  14. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Some shocks are valved to extend quickly for potholes and dampen on the compression stroke. Check with the manufacturer before fliping them over. The shocks would basically be useless when hitting bumbs because the damping effect of the shock will not be there. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  15. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    If they are made to run rod-end-down that's OK. I'd do it to keep the reservoir off of the sbring when that side is drooping. As for the length, it's all about droop.
  16. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Doetsch emailed back and said the prerunner line of shocks (which the 8403s are) can be run either way. Well, now i know.
    They can't be valved 50/50 so I still will run mine the right way.
    -- Mike
  17. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Mounting the shock in this manner also reduces unsprung weight to improve handling in racing applications. The heavy part of the shock is bolted to the frame leaving less mass on the suspension allowing it to react faster (only the piston &amp; rod move with the suspension). Great for race cars, but I doubt it would make a difference considering most of us run tires/wheels that are about 100+# each. It definitely makes a noticable improvement on motorcycles that use inverted forks.
  18. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    Couple diff.reasons.. looks diff., my 9000's are up like that to keep the dials from getting trashed, and helps keep the dirt out of the seals.
  19. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Mike,
    Huh? Compression is still compression.....whether the shock is inverted or not, same with rebound.
    The design of the shock may not allow it to run upside down effectively, but if you're talking about a shock that's spec'ed to run either way I think the point is moot.
    /forums/images/graemlins/smile.gif
