Why do roller cams require a special dist. gear?
Discussion in 'The Garage' started by fortcollinsram, Apr 19, 2004.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I was just thinking about it and I can't figure out WHY a roller cam require a bronze dist. gear?
    Chris
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I believe the cam is soft so you need a softer dist gear. Most companies can now make roller cams that will accpt a standard steel dist gear, I had one like this in my last motor. BTW - mine was a Crane brand cam. /forums/images/graemlins/thumb.gif
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Roller cams are machined from SAE 8620 billet steel and the gear on the cam isn't compatible with a cast iron distributor gear.
    The downside is that bronze does not have the stength of iron, so it wears at a higher rate.
  4. dyeager535
    26,975
    I would hope most of the newer aftermarket pieces for the street are all this way now, but as was mentioned, most companies now use a pressed on gear that is different material (I would hope same as dist.) so you don't have to worry about it.
