Why do YOU hate slipyokes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Feb 13, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I am leaving this as an opend ended question. Tell me how you have had trouble with yours.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    They leak like a bastard
    My Chevy isn't broken, its just out of gas.
  3. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i had a u-joint fail on me and it took out the slip yoke as well, but the bad part was when you loose a joint like that you can't leave the slip yoke in your case. so you end up spilling fluid all over the place. to where if i had a fixed yoke, there would be no spill and i could lock the front hubs, engage the transfercase into 4 hi and get home.
    <a target="_blank" href=http://community.webshots.com/user/bowtie1ton>My K5.</a>
    <a target="_blank" href=http://www.texasoffroad.net/galleries/members/midnight>http://www.texasoffroad.net/galleries/members/midnight</a>
  4. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Same problem here. One good thing is I will never have rust under that part of my trucks cab
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I won't have rust there either, but thats cause I'm lazy and never wipe the grease off the u-joint when I lube it...but yeah, its annoying how you can't pull the driveshaft and drive home.
    90K5
  6. 4x4machine
    4x4machine Registered Member
    Feb 10, 2002
    52
    Alberta, Canada
    Sorry to be the new dumb kid on the block, but what exactly is a slipyoke?
    drive it like you stole it
  7. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    the piece that connects your drive shaft to your transfer case
    it just slips off backward when you remove the drive shaft from the rear end, and what they are saying is in the event you trash your rear end, if you were to try and remove the drive shaft and drive home on the front axle, all the fluid would come out of the transfer case. as oppose to a fixed yoke that you could remove the drive shaft, and the yoke (and fluid) stays in the transfer case
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  8. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I don't like them because on a slip yoke application the tailshaft must be longer to accomodate it, with a fixed yoke you gain driveshaft length / angle from the shorter tailshaft. I also agree that the leak constantly.
    I recently swapped the tailshaft on my 205 from a slip type to a fixed yoke. No more leaks for me!!
    80 K10 w/ 468 and 1 ton stuff
    You don't scare me, I got chunks of guy's like you in my stool!
    www.nvrenuf.fws1.com
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    You can pull the drive shaft and drive home.Take the bottom of a plastic bottle or a plactic cup and place it over the extention housing and hold it on with a big hose clamp. It will hold the fluid in.
    What do I know,Im just a Ford guy [​IMG].<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  10. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    the yoke setup is better in regards to drive shaft movement. think about your slip yoke style when your rear diff drops down, requiring you driveshaft to lengthen, a spinning driveshaft that only expands by means of through a u joint then to a splined area that is at a different angle than your dirveshaft vs a yoke style dirveshaft where the splines allow the driveshaft to lengthen are "in line" with the driveshaft.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Leak like a sieve, clunk, and have left me stranded by spewing the fluid on the ground no less than 5 times in two years.
    My 208 is on its way out.
    Edit:
    Forgot the time I lost my rear u joint on I 80 @ 70 MPH. If that wasn't bad enough....when the shaft came out of the 'case, thet front slip yoke hit the ground and bye-bye slip yoke. $25 at a junkyard for a new one.
    Tim
  12. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Anyone have a picture of a slip joke? or slip yoke?
  13. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I have a picture of a broken one if you want it.. I just blew it out last weekend....Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  14. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Here's a picture of a slip yoke style driveshaft:
    http://community.webshots.com/user/zepplin1976
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The pic comes up as forbidden.
  16. klier
    klier Registered Member
    Jun 19, 2000
    88
    Faribault, Minnesota
  17. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    SLIP YOKES SUCK!!!!!! =(
    they leak, arent as strong, and make solving lift-related driveshaft vibe problems a biaaaaatch. Some of the high-end drive shaft makers dont like making shafts for slip yokes because of reliability issues....that says it all right now.
    As I have said before, once the new 205 I got goes in...and the old 208 goes out...i will never EVER have a slip yoke on my off-road rig again.
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  18. NE79
    NE79 1/2 ton status
    Mar 10, 2000
    177
    Nebraska City, NE
    did any years/t-cases come with a fixed yoke?
    uh-oh
  19. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Cause they suck. The slip yoke was another one of GM's Numb skull design ideas. Or whoever the hell designed it was out to lunch with no menu. And more than like was hitting the pipe a little too early in the morning.
    **WARN**ing, Something winching this way comes! [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
  20. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've been running with a slip yoke on my '90 for over 100,000 miles, about 40,000 of those have been with a 4" lift. I'm also using the stock driveshaft and the truck gets used pretty hard off-road. No problems so far.
