Why does my Blazz twist on bumps???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Jan 15, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    Salem ,Or
    I have a skyjacker 4" lift, skyjacker hydro shocks, add-a-leaf w/3.5"blocks in rear, ORD steering brace, new single rancho stabalizer, new 33's, new bearings, new everything suspension, 4" raised steering arm,and all new poly bushings.
    So I still have steering bump pretty good and on bumps going down the road it twists as it settles on compression, a left right, right left motion. WHY??? I've done everything I can think of. The only thing left is new springs in the back. So I could really use some input about now guys, and gals. Thanks, Matt.
    Displacement, cubes, and did you say you drive a riceburner???
  2. BurbinOR
    BurbinOR 3/4 ton status
    Sounds like you've done everything you can...............the solution from what I hear is crossover steering. The stock short pitman arm is our problem on these stock-steer trucks...........any small input to the wheels is transferred immediatetly through the pitman to the steering wheel. I have much the same experience with my Blazer, when we did the one ton conversion, with all new EVERYTHING from the frame down, it still has a small amount of bump steer. I too added new rear springs, so that probably won't make an impact for you either.
    I'm sure other's will chime in.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    What have you done with the swaybar? I have heard the ORD diconnect/correction kit is the way to go. Also I would really recomend ditching the single stabilizer setup for a dual unit. I would try those two items before you go through the bit expense of crossover steering. I'll also assume the frt end and gear box are both tight.
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
