why does my computer do this?
Discussion in 'The Lounge' started by bryguy00b, May 4, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i try to install windows and it says it dont have enough bytes..it gives me a long number which is like 7 or so GB's. or some times it will say "windows re"..and it will freeze like that and not display the rest of the message...but i know its suppost to say windows requires blablabla amount of space or w/e. i have run fidsk...put a new partition on it..tryed it over and over but i cant get it to get past the system check when i try to install 98. whats goin on?
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    After you run fdisk, make sure you format the drive as well.
    -->You have to run FDISK, then restart the computer, THEN format or it won't work <--
    If you're not formatting, it will look like you don't even have a hard disk, or that you have one with 0 bytes of free space /forums/images/graemlins/eek.gif Give that a whirl and see what happens. /forums/images/graemlins/thumb.gif
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how exactly do i format it? i dont know what to type..i run fdisk...and it says all drives should be formatted after i restart or something like that..but what do i type to format it?
  4. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    If you made a DOS boot disk, the format utility should be on there. Try running "format c:" from the floppy disk. If you're loading DOS from the Win98 CD, make sure you "start the computer with CD-ROM support," then go to your CD drive (probably D: if you only made one hard disk partition) and type "cd win98," then type "format c:" If this doesn't work, we'll try something else besides formatting.
  5. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Sounds like its broken to me.
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    geez you might be right...i never even thought of that.. /forums/images/graemlins/rotfl.gif
