Why does my lockright stay locked all the time?
Discussion in 'The Garage' started by hunterguy86, Apr 16, 2007.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I got a 14 bolt in my k5, with a lockright. The sucker stays locked all the time, never unlocks and is always dragging tires around the corner. The axle is full with 80-90 gear oil.
    What gives here? What should I look at?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    you have to be off the throttle for it to unlock, if it doesn't then, there may be something else wrong.
  3. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I wonder if it has to do with using a bit more throttle around corners since i have no freakin powersteering below 1000 RPM. I guess I will be able to tell after tonight because I will put a new pump on tonight after work.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh mine wont unlock if I am left foot braking and right foot on the gas to keep the powersteering workin quick, when I am having to maneuver through tight places in parkin lots. Let off the gas for normal turnin and its just fine
  5. goldwing2000
    goldwing2000 Guest
    Yeah, if you're powering around corners, it'll never unlock.
    Is your axle a 14bff or 14bsf?
  6. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Its a full floater.
  7. goldwing2000
    goldwing2000 Guest
    So, just curious here, why did you get a lockright instead of a Detroit?
  8. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Well the lockright is cheaper than the detroit and they are both lunchbox lockers so I figured there is no difference in strength at all.
  9. goldwing2000
    goldwing2000 Guest
    I'm sure there are plenty of people who would argue that point with you.
  10. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    I think what Dustin is trying to say is that a Lock-rite for a 14 bolt is put inside an open carrier, just like the Detroit is. That's why he's referring to it as a "lunch-box" locker. I can see both sides of the argument. I will say that yes the LR is less expensive but just as effective, but nothing will beat the durability, dependability and longevity of a Detroit. Sometimes, economics calls the shots. No shame in a Lock-rite.
    Now, how about that lunch box? I'm starved!
  11. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    the detroit reuses the stock 14 bolt carrier, right? in other third members, it replaces it, so the detroit and lockright may be closer in strength in the case of the 14 bolt than in other applications. detroit is still probably a little better, though. you get what you pay for, in many cases. that said, i've heard very good things about the lockright. lots of "it's lasted way longer than i expected" stories.
  12. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Hunter do you have an auto or manual trans? When you decelerate with a lockright with a manual trans it puts load on the diff and locks it.
  13. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I have a 700R4.
    Since correcting the powersteering issues, the locker works like it used to and is a joy to drive again.
