Why does my truck hate me?????
Discussion in 'The Garage' started by shaun, Feb 22, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Well I got the lift put on and new brake lines but now I cant get the brakes to work. I was able to bleed them and it was all fine. Then I replaced the banjo washers on the front checked all my bleeder screws and now it just depresses to the floor everytime (very little resistence) It looks like there is a little fluid on the frame below the Master Cylinder. It seems like there might be a little on the master cylinder right in front where the MC connects to the booster. What is going on? Did I break something??? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if you blead them then changed the banjo washers then you need to bleed them again
  3. shaun
    Apr 22, 2003
    745
    No i replaced the washers then bleed them. Sorry if I wasnt clear on that. /forums/images/graemlins/doah.gif
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    If you have fluid on the MC where it bolts up to the booster, then you have a bad MC. That will cause the pedal to drop like you describe.
  5. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Sounds like the rubber seal that the mc rod passes through has a tear in it. That will cause a leak, and introduce air in the system every time you pump the pedal. I'd just buy a new mc, and be sure to bench bleed it first.
    Tom /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  6. shaun
    Apr 22, 2003
    745
    Bought a new MC and ended up buying new calipes too b/c the dumba$$ previous owner (i hate those guys) broke off the nut tops for the bvleeder screws. They are still a little squishy now but a lot better. Now let it all settle and do a lot of checking this weekend. Thanks for the help. /forums/images/graemlins/waytogo.gif
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    Sometimes bleeding the brakes a lot causes the MC to fail. There can be crud in there that never causes problems until you start pumping it to the floor. Then you can mess up a seal and the MC goes bad. Good thing brake parts for these trucks are so affordable /forums/images/graemlins/thumb.gif
  8. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    if you have rear drum brakes make sure they are adjusted up properly....so the shoes drag slightly when turning the wheel by hand. If they are not adjusted you can damage the MC or rear wheel cylinders when bleeding. Make sure your rears are adjusted before bleeding next time and you should be good to go /forums/images/graemlins/thumb.gif
