Why does no one use gas welding...
Discussion in 'The Garage' started by 84k5, Oct 29, 2003.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Everyone buys a mig. Seems like oxy-acetylene will weld any thickness you could want, and you can use it to cut metal. Don't have to have to mess with installing an electrical outlet for it either. Please enlighten me /forums/images/graemlins/confused.gif. --Brian
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Mig Welding is a lot easier,Less heat transfered to the metal
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Gas welding is slower and more tedious plus it requires more skill and a steady hand to do a good job.
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    oxy/acet welding also doesn't add any filler metal to the welding surface. You are only ending up with the same strength if not less when you weld with this process.
    With MIG welding, you are using a filler metal that will actually add to the strength of the original metal and if welded correctly, will make the 2 pieces stronger than if they were a single piece.
    Plus it's a hell of a lot easier /forums/images/graemlins/smile.gif
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    so what do you guys use to cut plate and tube? I'm on a tight budget and starting from scratch. TIA -- Brian
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Uh, you may want to check on that, you add filler when oxy welding just like tig welding... 30" or so long rod of filler dipped in flux...
  7. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    back in the 80's we use to braze quarters on, on a daily basis at the bodyshop..
    i do know it was "illegal" for us to torchweld frames tho... or at least so i was told...
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I use a torch to cut everything ATM but have plans to buy a chop saw or horizontal band saw for the small stuff like tubing, angle iron, channel, etc... For welding I use my mig welder for sheetmetal and lighter welding and break out my stick welder for the heavy stuff.
  9. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Mig is faster, less expensive,[once you have initial investment paid for] only one bottle to refill, only one roll of wire to buy [depend's on hard wire, or flux cored, or aluminum, [if set up for aluminum].
    A oxy/acetylene is used mainly for cutting heavy metal anymore, up to 3/8" can be cut with a plasma cutter, thicker material can be cut with a bigger plasma cutter.
    It's like anything else, what worked in the past has ben replaced buy something new and updated. Doe's anyone use a typewriter anymore? Hell no, it's done by computer, doe's a pen's quill have to be dipped in ink to write? No just grab another Bic. /forums/images/graemlins/grin.gif
  10. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I've welded a few projects with oxy/act welding. It's been a few years but I still have a bunch of rod. I have a AC/DC buzz box and a MIG now - it's just way easier and alot quicker to use those then gas weld.
  11. Waxer
    1,857
    Long Beach, CA.
    Are you referring to Brazing then? I've welded in the past in body shop with just 2 pieces of 1/4" plate, no filler, using the torch. It was fairly easy to do, just not AS easy as MIG.
    Either way, its old tech and not necessary anymore.
  12. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    are you trying to say you just "melted" the pieces together with the torch?
    no way you have to use some kind of filler or youre just heating up the metal
    Later
  13. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    hehe, we used to torchweld with coathangars for that "extra" strength... /forums/images/graemlins/wink.gif
    what a pain in the arse... gimme a mig anyday...
  14. inscape
    inscape Registered Member
    Oct 30, 2003
    82
    Washington
    My dad use to do intricate welds on candle holders and things like that with a gas welder. That was about 8 years ago, he doesn't weld anymore.
  15. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    You need more heat when Gas welding...
    more chance for warpage...
    Also speed...It will take 3 times longer than MIG!!!
  16. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    if you take a look at "the welding handbook" it talks at great length about oa welding. there are times when it is the way to go, especially with one of the dillon/henrob torches, but it is generally slower, more difficult, and heat intensive than any other welding process commonly in use. I'm not sure about oa welding with no filler, as I have only seen it done and done it with a filler rod and flux as was mentioned below.
  17. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    You can Oxy-Fuel weld with or without a filler rod. If without rod, the join needs to be laid out with that in mind. Metal always shrinks at the weld puddle and w/o filler this has to be accounted for.
    A change in cross section is a stress riser. So a butt weld with a bead that is proud to the surface of the joined metals is a stress riser. Grind it flat and the stress riser goes away. Tell me again how welding with filler will make two parts stronger than one ? In certain specific situations I can see it, but not as a blanket statement.
    Flux is typically only used with brazing and on aluminum. Nearly all Aluminum bodied sports cars are built using oxy-fuel welding. MIG or TIG welding in those alloys results in a weld bead that is too brittle to metal-work. Brazing is more like soldering than welding in the way it is classified.
    If you can oxy-fuel weld it's an easy step to learning to TIG weld.
  18. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    A very easy step indeed. Personally I think TIG is alot easier then the torch.
    Evan
  19. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    Oxy-acetylene welding is preferred when you have to do hammer and dolly work on the weld. The weld's properties are nearer to those of the base metal. Also it seems that a lot of people that try it to weld sheet metal use a tip that is oversized, then have trouble with warpage. It is slower but also I think kind of relaxing, no noise or sparks going everywhere.
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It's also preferred for fixing things like fatigue cracks in door bulkheads where the hinge work hardens the area, or around the door striker, hood hinge mount, etc. Welding with a torch anneals the whole area, and if you need to spread it around even more, you can easily do so. Weld the same crack with a MIG and you will often get another crack in short order.
