Why does the Heater/AC Fan never turn compleatly off?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Jun 5, 2002.
    Even though I turn it to the "off" position the heater/ac fan is still on a little bit, and pushes some air out. Why? Anyone else have this problem? Thanks -80K20
  1. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    It is what GM refers to as their "fresh air"system. Even in the "off" position the fan will run at a low speed to make sure the occupants have fresh air to breath.
  2. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    I would also think that cruising down the interstate at 7o mph that the fan would turn because the wind was hitting it and pushing air up the vents. just like a windmill.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    like Mr.Chevy4x4 said, it is supposed to do that, since new.
    I pulled the wire for it because I thought it was annoying. When I get A/C, I guess I'll put it back like it was and live with it.
    -- Mike
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, it's supposed to do that. Keeps fresh air flowing into the cab all the time.
  5. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    It also helps prevent spores and mold from building up in the Heater/AC box. So when you get in your truck it doesn't smell like a dirty diaper.
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Most are supposed to do that. I didn't like it, so I replaced my 3 position switch with a 4 position and now have a true off (required slight modifification to the end that plugs into the switch).
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I just killed that by
    pulling the resistor pack out from the heater box in the engine compartment
    cut out the low resistor
    put it back in the heater box
    now the 'off' is 'off'
    there are 3 pins.
    one pin has 2 wires, one from dash and one to the blower motor, that is 'high'
    centre pin is 'medium', current flows through one el cheapo resisant wire
    third pin is 'low/off', current flows through 2 resistant wires
  8. dyeager535
    26,982
    191
    Not all of them are setup this way. AC setups off is off, as well as the HD heater option. I believe early 80's GM changed the system so that the fan actually shuts off when in the off position.
    IIRC, with non AC vehicles, "OFF" on the fan speed switch means its off. "OFF" on the slider for vent/defrost only=fan running always.
  9. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    what is IIRC ive seen it mentioned in other post recently but not sure what it means?
  10. dyeager535
    26,982
    191
    If I Remeber Correctly. For those of us with extremely short memories : )
  11. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    In every Chevy truck I have ever owned from '77 on up(with AC or without) the fan motor has always run any time the ignition switch was on, even when the fan switch was off.
  12. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Like mentioned before, not all of the trucks do this.
    My '77 Blazer would run all the time, but my '81 and '86 don't. They shut off completely. An '83 C-20 and '86 Suburban I used to have also shut off completely. All of the trucks had/have A/C. I believe that '80 and older trucks have this feature, and the newer ones don't. But I'm not sure.
    Casey
  13. dyeager535
    26,982
    191
    My '81-up HD heater says otherwise : )
    Like I said, I haven't seen enough '81-up trucks without AC to know for sure, but I owned an '83 with AC, and the fan shut off. My friend has an '84(?) with no AC and no HD heater, and I can find out what I already know next time I talk to him. It shuts off.
  14. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have no A/C as a factory option and its when in the OFF position the fan always runs....If I kick it into high speed it blows harder (mind you while still on off) if I turn the high switch all the way past low it turns off completely
  15. YtseJam
    May 19, 2002
    147
    CT USA
    The fan always runs when the ignition is switched on. If it does not run than something is wrong with it. All trucks with or without AC came through this way. And it is said to keep the heater box dry and free of that mildew smell.
