WHY DOESN"T ANYONE USE A STERLING 10.25 REAR???
Discussion in 'The Garage' started by boggerless, Mar 3, 2004.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    WHY DOESN\"T ANYONE USE A STERLING 10.25 REAR???
    is it to labor intensive or just not worth it? thanks /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: WHY DOESN\"T ANYONE USE A STERLING 10.25 REAR???
    Its a Ford and a 14FF can be found 99% easier, faster and cheaper than a Sterling rear. /forums/images/graemlins/thinking.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've never seen a single one in the junkyard. 14 bolts are a dime a dozen. I've got one in all three of my trucks. /forums/images/graemlins/thumb.gif
  4. boggerless
    May 26, 2003
    22,728
    96
    seems alot of people on here drive fords daily,must be the solid front axle. /forums/images/graemlins/grin.gifso is it worth it with the way 60 front ends are going away,why not something else? is there something wrong with the sterling front axle? /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gif to /forums/images/graemlins/truck.gif
  5. boggerless
    May 26, 2003
    22,728
    96
    just wondering. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    theres a 79 bowtie or was, in town with a 10.25 rear and chevrolet d60 front.. weird as hell to be walking into the back of xtreme suspensions shop and see chevrolet taillights, and the framiliar Mag-Tech Diff Cover for sterlings..
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lol I saw a bronco at the local 4wd show with a Ford HP 60 front and a 14 bolt in the rear. Owner was talking to me about his rig and I was like, "HEY, WAIT A MINUTE, IS THAT A 14 BOLT?"
    His reply?
    "Sure is, I love 'em. Cheap, too!!"
  8. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    is there something wrong with the sterling front axle.
    there is someting wrong with the sterling front axle seeing as there is no such thing. they are only rear. the 14B may be a boat anchor but the detroit loker is like $100 cheaper and thay are a dime a dozon.
    Just my .02 worth
    Andrew
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I knew activating the Search feature would turn it up..........
    There was a guy hanging out here that had one in his truck, profile is here.
    Haven't seen him around for awhile.......
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    14BFF's are stronger and heavier. Plus they had probs. with the bolts backing out of the ring gear/carrier on those sterling axles. Besides why put a ford part under a chevy when a 3/4 14BFF bolts right in and is better anyway.
    Boggerless, A ford truck that has a 10.25" sterling rear should have a D60 front axle.
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    WRONG, the put the sterlings in alot of 3/4 tons and those still had the TTB dana 44 or 50?
  12. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Swapped in a 10.25 Sterling into my 90 Bronco rear. It was a semi-floater and later when I found that there were minimal lockers made for it, I regretted it. Had I gone with the full floater, I may have stayed with the Bronco, swapped in a D60 front end for the TTB, and I wouldn't be here. But, the GM products are just too easy to work on and readily available.
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Or also a D61 front axle. Yep, D61. Its kind of like the D60 but parts between them will not interchange. Just another one of those Ford engineering things where they had to try to fix something that wasn't broke. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You'd appreciate them if you wanted to put 3.08s in your D60. /forums/images/graemlins/rotfl.gif
  15. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    SORRY, /forums/images/graemlins/grin.gif I remembered right when I hit the "submit" button. Not if it's a newer super duty, they come with a D60 in BOTH 3/4 and 1 ton models. I think the FF sterlings were only under 1 ton's. I think. /forums/images/graemlins/tongue.gif For the older stuff...I know... I know...it's just like the chevy's 3/4= 44/14B, ford 44/sterling. I forgot for a sec. /forums/images/graemlins/doah.gif
  16. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I had a 84 f250, It had the 10.25 sterling. Nobody uses them, because their aren't many gear options and lockers are outragious!!
  17. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    A D61 front in a Ford?! /forums/images/graemlins/confused.gif
    I've never seen a listing for a reverse-spiral (aka hi-pinion) D61 gearset.
    Dodge used a D61 front in some of their early Cummins trucks. 3.07 ratio I believe. Standard-spiral (lo-pinion). I think it was the non-intercooled with 727 auto that got it.
    The 10.25" Sterling does have a nice meaty Trac-Lok - something you won't find for a 14bFF. Earlier ones had problems with the crush sleeve failing. 93-up models are redesigned. Gearing available from 3.08 to 5.13 and even 7.17 /forums/images/graemlins/eek.gif Have a look at the tooth engagement on one of these. Its got a Dana 60/70 beat hands down. /forums/images/graemlins/yikes.gif
  18. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I think they are one of the most "overlooked" rear end options out there.... They don't hang as low as a 14bFF. Within the next year or so, I've got one I'm gonna try running....
    Marv
  19. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If its that new it uses a Sterling 10.5, not the 10.25.
  20. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Zonkrat uses one in the rear and a Ford D60 front in his IFS deleted truck. It was a good looking swap and very much "built not bought" He's been on the road alot so not much time on here.
