Why doesn't anyone make...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bogginnut, Jun 28, 2002.
  1. bogginnut
    bogginnut Registered Member
    Jan 6, 2002
    82
    Jacksonville, Florida
    Why doesn\'t anyone make...
    ...cut and tap style slip yoke eliminators for the 208 t-case. I did this for the 207 in my Heep and it works awesome. Seems like this could be done for the 208 as well. /forums/images/icons/confused.gif
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Re: Why doesn\'t anyone make...
    There's a member here that's built a fixed yoke NP208...using the rear half of a Dodge 208 case.
    K10ANDY (can't remember how to spell his last name...)/forums/images/icons/blush.gif
    Rene
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    Rene , hey its not my last name , its " mechanic" said at 3 am while installing a 350 hehe . yes did convert a 208 and now it is for sale ...or i could tell ya how to do it ...
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    LOL...
    Rene
  5. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    what you want for it?
    Later
  6. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    250$ OBO considering all the time R and D and all .....tell me if im crazy /forums/images/icons/smirk.gif
  7. bogginnut
    Jan 6, 2002
    82
    so how did you do it?
  8. bogginnut
    Jan 6, 2002
    82
    still no answer to my question. Is it possible to drill and tap the output, then bore the yoke so a bolt can pass thru? Seems that one of the fabricators that hang here could do this no problem. That person could make a killing if it worked.
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    As far as I know Andy bolted up the rear half of a Dodge 208 case to his Chevy 208. The Dodge's came fixed yoke from the factory. This would seem like the least expensive way to get the fixed yoke on a 208.
    If you are looking for custom type work to modfiy your Chevy 208 you need a machinist not a fabricator. I believe Jesse at High Angle Driveline was looking into a SYE kit for the 208, but for whatever reason decided it was either not economically feasible or ???.
    I'd look into swapping the Dodge rear half, or option 2 is swapping in a 241 and adding a SYE kit, or option 3 is to swap in a 205. Option 4 is to pay through the nose for machining and R&D time to make your own SYE kit for your 208...
    Rene
  10. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    What yr dodge stuff is needed? And what parts are needed? I may be able to find one throgh one of the salvage yards that has the front stuff blasted off from a hard front impact. (hit hard right+knock axle back to compress slip yoke+blasts off front output half of case=cheap.) /forums/images/icons/smile.gif
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    pm K10ANDY....he'd know for sure. I imagine it would be early 80's like the Chev application. I know the newer Dodges used the 231HD T-case (1/2 ton), but I'm not sure when the change was.
    Rene
  12. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Thanx Rene!
  13. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    OK YOU ASKED FOR IT ! /forums/images/icons/wink.gifok here goes guys .
    first u need a good chevy 208 .
    then u need the ( rear half , the tailhousing , and the mainshaft ) from a dodge 208 . there are about 3 things that need to be done the dodge parts . first the rear half needs a new shoft rod support , u should get a new piece of aluminnum mahcined and tig welded to it . the dodge case lacks a support rod bolt hole so if u are worried u can cut the one off a a chevy case and weld it on . then if i was going to do mine again i would move / drill and tap and new fill hole , now i just put studs in the front and fill it before i put it on . check out this link for a picture of the parts needed and the finished case.
    after you do all this swap the chevy parts onto the dodge shaft except for the oil pump and speedo gear .
  14. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    that might work but the dodge way seems to be a better way makes for a longer rear driveline.
  15. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    tRusty,
    Jesse could not get the parts, they have all been discountinued. So he came up with this as a solution for the guys running the 208's;
    This slip yoke set up has splines that run the full depth of the yoke, and allow people to run Jesse's bullet proof One Ton CV setup without having to switch to a fixed yoke.
  16. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Thanks for clearing that up Jeff. I knew there wasn't gonna be a kit...I was just unsure of the reason.
    Rene
  17. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    UMM are you talking in the end of the shaft or sideways through it ? i think you would need at least a 1/2 inch grade 8 bolt . i have enuff parts to test it so i thatnks fo the idea . -Andy
  18. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    There is no way you could drill and tap into the end of the output shaft. It would have to be done previous to the heat treating, once it's been heat treated it's harder than any drill bit or tap would be.
    rene
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ouch.
  20. gpd4
    gpd4 Registered Member
    Jun 25, 2001
    55
    St. Louis, MO
    A two fluted carbide end mill should cut it. Tapping it would be another story...
