Why I don't like 1/2 tons Part II
Discussion in 'The Garage' started by mountainexplorer, May 29, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Not only can I not haul much, but I can't even powerbrake in a Wal Mart parking lot without this happening.
    It was going to be the first time to finally not have to drive my 7mpg Crew Cab back and forth from place to place, and look what ends up happening.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I like it.
  3. mountainexplorer
    Nov 14, 2001
    4,903
    After spending time yanking another 10-bolt carrier from a parts axle I had, swapping ring gears, and putting it back together to have one tooth on the pinion gear bind up with the ring gear creating a clunk... I've decided to convert the truck to 3/4 ton.
    I hate semi-floater rear ends, but I have a 14-bolt SF rear with 3.73's and matching e-brake cables to bolt right into the truck. Along with some 3/4 ton 52" rear springs and 8-lug outers for the front... different u-bolts, rear driveline, 8-lug rims, and I should have it back to daily driver status again.
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah good time for an upgrade.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I have the same problem. Only once have I broken an axleshaft but on at least 5 different 10 and 12 bolts I have opened them up and they looked like that or worse. My latest failure was on an '03 Z71 burb. Broke two spider gears in half and sheered the retaining pin (gov-bomb equiped).
    I can say that I have had good luck with the 14SF axle though
  6. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    mmmmmmm 10 bolt spider soup :doah:
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Aren't they designed to do that?
  8. resurrected_jimmy
    May 23, 2005
    2,241
    yeah its called a torque fuse. In laymen terms it means do not ever try and actually use this rearend:rolleyes:
  9. mountainexplorer
    Nov 14, 2001
    4,903
    Usually, when I get a good 10-bolt rear (good meaning, nothing broken in it, since I call 10-bolts bad regardless), I try and sell the 1/2 ton stuff which sells easy because other people break theirs and need replacement.
    Then I get cash for what I consider junk and swap in 3/4 ton stuff and don't have to worry about it.
    I almost did that with this truck, but since the rear end was rebuilt, I figured I'd leave it 1/2 ton since I was going to just sell the truck eventually anyways. Guess I should have done what I normally do. Then I coulda gotten cash for the 1/2 ton stuff and ended up doing the same amount of work as I have to now. Only now the 1/2 ton stuff has no value to resell.
  10. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    well what did you expect just letting those bolts and chunks of metal float around in there?:haha: 1/2ton stuff is crap!!
    On a side note what are the specs of the truck in your avatar?
  11. mountainexplorer
    Nov 14, 2001
    4,903
    Well, it was all intact and in good shape until the big boom. After that it got pulled onto my car trailer and then taken apart.
    The red '83 in the avatar has a Goodwrench 350 with Isky 270 cam, headers, Edelbrock intake and Carb, SM465, NP205, 14-bolt with Detroit, Dana 60 front welded, 4.88 gears, about an 8" lift and 40" tires. It's currently sitting cause I broke the 10-spline coupler between the tranny and T-case. http://video.google.com/videoplay?docid=659932050617184725
  12. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    you have anymore pics of it?
  13. mountainexplorer
    Nov 14, 2001
    4,903
  14. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    didn't you learn after seeing what I did to my 10 bolt?
    and btw you suck you have the parts to swap it to 3/4ton. I would loved to have done that when my rearend blew instead of putting more money back into the 10bolt
  15. goldwing2000
    goldwing2000 Guest
    It looks funny with those itty-bitty tires. Like an elephant wearing ballet slippers. :D
  16. mountainexplorer
    Nov 14, 2001
    4,903
    Hey, how many times did I say you should just make it 3/4 ton in years past before you broke it? :p:
    That '85 3/4 ton 4x4 Suburban that I got the 350 out of for the yellow truck is now donating it's 14 bolt semi-floater rear end to it too.
  17. eclipse
    Jan 1, 2005
    1,245
    Sparks, NV
    wouldn't have costed me much more to do the 3/4ton swap, but then I owuldn't have needed wheels and tires. Bader had a set, but that wouldn't ahve been another 350 dollars. so instead of the 350 to fix the 10 bolt, would have been around a 1000 total. I would have loved too, and those tires I wanted look sweet on someone elses burb he just swapped to 3/4ton
