Why is a 400 Small block not a big block?
Discussion in 'The Garage' started by grumpy, Apr 29, 2002.
  1. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    I got asked that question today and couldn't come up with and answer. Small blocks differ from big blocks because the stroke is longer right?
    David
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Everything on a big block is bigger. THe heads, bore, stroke, mains. It is weird though that they have a 400 small blocks and a 396 big block /forums/images/icons/smile.gif Thats why I like pontiacs. They are all the same and all are considered big blocks, evn the 326 /forums/images/icons/smile.gif
  3. Sledge
    Sledge Registered Member
    Feb 24, 2000
    75
    Reno, NV
    It's not a matter of displacement, just the external dimensions of the block itself. Small blocks have the same external dimensions from the 265 up to the 400, regardless of their internal differences in bore and stroke.
    You have to think physical dimensions, not displacement when considering "big block" or "small block." /forums/images/icons/smile.gif
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    also the head design makes them totally different.
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Studeabaker made a 289 Big Block!!!
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I thought they used fords 289?
