Why is my basement flooded?
Discussion in 'The Lounge' started by newyorkin, Feb 20, 2003.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    No major leakage anywhere, just lotsa water on the floor. All the snow outside is melting, so the ground is saturated. I just can't seem to identify where this is coming in. It seems like it's soaking through the cinder block walls, but I can't find where. There are wet spots on the walls in other parts ofthe basement, but not near the floods... It looks like it could be wet, but I can't tell, and it's way below ground level.
    Any thoughts, anyone??
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    when i was little i remember watching hometime with my parents and i remember one where these peoples basement would fill with water because the ground water was high or something. The water would actually leach through the concrete blocks and fill the basement. They painted the walls with a paint that repels the water. The only one i could find online was this stuff Expensive but if i remember right this was the stuff they used on hometime. Might try a pump under the floor if you want.
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Sounds to me like you need to invest in some masonry sealer Ratch. I think the stuff I used befor was called UGL or something like that, it goes on like real thick paint. A few coats sould seal it up if that is your problem.
  4. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    K20, if you knew what we've spent on paint in the last 2 months, you'd think that stuff was cheap... Gettin irritated just thinking about how much we've wasted...
    The exterior of our house is stucco, so I just happen to have some masonry sealer I was using last summer. I guess I'll put some of that on the basement walls if they dry by the weekend.
    Thanks for the tips, guys!
  5. chevblazk5
    chevblazk5 1/2 ton status Premium Member
    Mar 19, 2002
    257
    Sayreville, NJ
    I had a same problem in my basement three months ago. No leaks just wet walls. I bought two gallons of DryLock and painted the walls. That solved the problem. However, in my case this is just the beginning. I got a small excavator from one of the local contractors and I excavated few test pits at back side of the house where the walls are wet. (I first called for all utilities mark out and I got all required permits) What I found just made me mad!!!! When the previous owner had the addition added on, his contractor never sealed/waterproofed the foundation from the outside. This is just stupid and inexcusable!!! I’ll have to excavate the whole back side of the house and seal the foundation this spring.
    Well anyway, I hope your problem is not as serious as mine.
  6. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    A house I used to own didnt leak real bad, but thefloor drain would back up after a real bad rain. I dont know if you have a drain, but if so, its a possibility.
  7. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    The house my parents owned when I was a kid had a natural spring under the house. They had to install 3 sump-pumps. Every time it rained or the snow melted, the basement would fill up. I remember how we found out. My grandfather and I were down there in the water and he had the idea to punch a hole in the floor to let the water drain out. He hit it with a punch and the water shot out and hit the ceiling! My dad yelled "we're going under!" /forums/images/graemlins/rotfl.gif
  8. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    After 15 years doing residential renovations, 1 thing stands true...if you dont get the water away from the house, it will come back to haunt you. Using dry-lock or equiv is like putting a band-aid on a cut off arm. the water is still getting in the block, and it will not take long for it to destroy the integrity of the block, thus at first it will start sinking. That is a big cause of so many houses having cracks in the sheetrock. If you leave it be at that point, the house goes. Sorry, but you might need to get a french drain and pump set-up.
