Why is my brake light on?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, May 19, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I have a 1979 K5 Blazer? What makes the brake light on the dash come on? It has been on since my axel swap. I do not see any wires conected to the master cylinder. There is not low fluid? The brakes are spoongy though.
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    check the wire at the parking brake try unhooking it there to see if light gos off make sure the parking brake pedal is all the way up or this will cause it to stay on also check the wire going to the porprostion valve its on the frame under the radiator you may also need to bleed your brakes again
  3. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Got the parking brake removed still on? Will try bleeding again.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The spongy pedal is the clue. There is air in the brakes somewhere. Bleed 'em good. If you had the brakeline unhooked long enough for the resevoir to run dry on the master cylinder, then you'll need to start by bleeding the master cylinder first. Then move on to bleeding the rest of the brake circuit.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Harry is right. That light is a pressure sensing thing. WHen it senses some kinda pressure drop somewhere in the system it'll come on. I've had ne come on while on the brakes slowly coming down some steep trails.
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Reverse bleed them all by pumping brake fluid up from the bleeders. Light is off and brakes are firm. Now I need to get a steering stabilizer because this thing is walking all over the road now with the 38.5" I'll have more pics up soon. Thanks for the help guys ;-)
